ABS fault and TRACTION fault - Chevy Colorado & GMC Canyon
post #1 of 8 (permalink) Old 08-26-2012, 02:57 PM Thread Starter
nestorgarcia577's Avatar
i keep getting this message on the screen on the dash board that when i turn my truck on it says abs fault and traction fault and the abs light stays on and the brake light stay on...but the brake is not on...its realeased but it says its on..if somebody knows what it is or an idea i GREATLY APPRECIATE IT
nestorgarcia577 is offline
post #2 of 8 (permalink) Old 08-26-2012, 03:12 PM
08Canyon's Avatar
Have you done any work to the truck? Most times it's the abs ring in the front hub. It has to be perfectly seated. I'm sure the traction fault is due to abs.
post #3 of 8 (permalink) Old 08-26-2012, 03:23 PM Thread Starter
no i havent done any work to it really...they keep telling me it could be the speed sensor but then again i really dont know if thats whats causing it to throw all them lights at me
post #4 of 8 (permalink) Old 08-26-2012, 04:03 PM
Id go with the wheel speed sensor. Ive had many of them go bad over the years on different vehicles and thats exactly what happens with the lights. Finding which one is the culprit is the hard part.
lukpat23 is offline
post #5 of 8 (permalink) Old 08-26-2012, 04:18 PM
A VICTORY STICK's Avatar
It could be a bad abs sensors thr thing with that is they are a two piece unit one reading the wheel speed and the one in the hub if it is in the hub, the hub must be replaced because they are not servicable. good luck
AEM intake tube. Airrade throttle body spacer. Supermode throttle body. Supermod spring delete. denso plugs. AVT tune.Jet stage 2 chip and custom exhust. and many others
A VICTORY STICK is offline
post #6 of 8 (permalink) Old 08-26-2012, 04:43 PM Thread Starter
thanks for all your help...
post #7 of 8 (permalink) Old 08-26-2012, 08:56 PM
Yeah, It should be a wheel speed sensor (same thing as an ABS sensor) check especially the front two to make sure you didnt get a wire pinched and broke some how, ive seen that too. Make sure that the pigtail is plugged into the hub good and that the ends are not corroded. If that all checks good then its time to replace the hubs.
lukpat23 is offline
post #8 of 8 (permalink) Old 08-26-2012, 09:57 PM Thread Starter
Thankz lukpat23....im gonna have to try the speed aensor first and then go from there and see what happens then...thankz
