Ultimate Static Drop FAQ, How To's, Part #s and Helpful Info - Page 2 - Chevy Colorado & GMC Canyon
post #21 of 79 (permalink) Old 08-06-2007, 09:45 PM Thread Starter
I dunno around 1700. The front coil over kit alone was 1200.
Good luck
brewer15650 is offline
post #22 of 79 (permalink) Old 09-22-2007, 12:04 AM
i dont know if you guys deal w/ the same. but i just lowrd my zq8 2/3 and c-notch, it still hits on dips and driveshaft hits on hard acceleration.
ihaveonetoo is offline
post #23 of 79 (permalink) Old 09-24-2007, 12:28 PM Thread Starter
What is your drive shaft hitting. Im 4 1/2 in the back and i have no problems.
post #24 of 79 (permalink) Old 09-24-2007, 01:41 PM
Re: Ultimte Static Drop FAQ, How To's, Part #s and Helpful I
[quote="burn"][quote="brewer15650"]Lowering Products
BellTech Suspensions http://www.belltechcorp.com
1β€
burn is offline
post #25 of 79 (permalink) Old 12-19-2007, 12:42 PM
Send a message via MSN to adidas_man Send a message via Yahoo to adidas_man
Just an update:
Belltech Nitro Drop Shock P# 7503 are being phased out and being replaced by:
Belltech Nitro Drop Shock 2 P# 8502
2005 Honda S2000 - DD
2007 Xtreme Crew Cab - SOLD
adidas_man is offline
post #26 of 79 (permalink) Old 01-25-2008, 12:01 PM
rsvongsawat's Avatar
Send a message via AIM to rsvongsawat
I have noticed that the passneger side is higher than the driver side (after the drop) I really DONT want to cut anything.. is there any other way to remedy this problem? I'm riding a 2004 GMC Canyon with a 3/3 DJM lowering kit (control arms in the front & blocks in the back)
rsvongsawat is offline
post #27 of 79 (permalink) Old 01-25-2008, 05:19 PM
Welcome, you've just discovered the Chevy lean. 99% of these trucks have it, nothing abnormal.
If you don't wanna cut the coils, you can certainly waste your money on the Belltech spacers to shim the driver's side up.
I'd just cut it, but it's your truck and your money.
Grounded Member #55
My Car Domain
rrcn is offline
post #28 of 79 (permalink) Old 03-18-2008, 04:51 AM
CALI-BOSS
DBNissan's Avatar
DBNissan is offline
post #29 of 79 (permalink) Old 03-24-2008, 07:35 PM
Re:
WHOA!!!!!! All of the FAQ data is missing!!! AHHHHHHHHHHHHHHHHHHHHHHHH
(which you obviously have figured out - LOL)
Get the Belltech 25005 adjustable front shocks and leave all of the passanger side shims out.
burn is offline
post #30 of 79 (permalink) Old 03-25-2008, 05:24 PM Thread Starter
Re: Re:
Weird I havent touched that thread since..... Last edited by brewer15650 on Mon Mar 05, 2007 12:09 pm, edited 3 times in total. Must have lost it during the upgrade?
post #31 of 79 (permalink) Old 03-27-2008, 11:16 PM
Re: Ultimate Static Drop FAQ, How To's, Part #s and Helpful Info
Found it on that other site that we aren't allowed to mention around here:
Here is a list of Suspension Parts Indexed by Company. If you have any questions Please post them and I will try to answer them as soon as I can.
BellTech Suspensions – http://www.belltechcorp.com
Springs & Shocks.
* 1” Regular Cab Front Springs Part# 4201
* 1” Crew Cab and Ext Cab Front Springs Part# 4205
* 2” Regular Cab Front Springs Part# 4203
* 2” Crew Cab and Ext Cab Front Springs Part# 4206
* 1" or 2" PRO Kit for Regular Cab Part# 12203
* 1" or 2" PRO Kit for Crew Cab and Ext Cab Part# 12206
**Pro kit Part#12203 consists of lowering springs, Spring Distance Spacers and Leveling Spacers.
Lowered Front Shocks with new damping technology that retains the use of the stock coil springs.
* Drop Front Shock 0"/-1"/-2" Part# 25005
* Rear Non height Adjustable Part# 22096
Adjustable.
* 0-3” Front Shock Coil Over Combo Height Adjustable (Fixed Damping Galvanized) Part# 12001
* 0-3” Front Shock Coil Over Combo Height Adjustable (Fixed Damping Galvanized) with rear shocks Part# 13001
* 0-3” Front Shock Coil Over Combo Height Adjustable, Damping Adjustable and Stainless Steel w/ Rear Damping Shocks for use with lowering leaf springs Part# 21001
* 0-3” Front Shock Coil Over Combo Height Adjustable, Damping Adjustable and Stainless Steel w/ Rear Damping Shocks for use with factory leaf springs Part# 21003
Rear.
* 1” Lowering Blocks W/ U-Bolts Part# 6010
* 2” Lowering Blocks W/ U-Bolts Part# 6110
* 3” Lowering Blocks W/ U-Bolts Part# 6210
* Rear U-Bolt Kit With Hardware Part# 6205
* 3” Rear Leaf Springs Part# 5953
* Rear Nitro-Drop Shocks 3”-5” Part# 7503
* Rear Nitro-Active Shocks 3”-5” Part# 10503
Pinion Kits.
* Pinion Shim Kit 1 Degree Part# 4973
* Pinion Shim Kit 2 Degree Part# 4975
* Pinion Shim Kit 3 Degree Part# 4976
* Pinion Shim Kit 4 Degree Part# 4977
* Pinion Shim Kit 6 Degree Part# 4979
Miscellaneous.
* 2” Drop Ball Joints Part# 2103
* Front Sway Bar Kit 1.25” Diameter Part# 5421
* Rear Sway Bar Kit 1" Diameter Part# 5521
* Rear Frame C-Notch Part# 6603
* Replacement Tranny Crossmember (gain 2.25” of clearance) Part# 6963
* Coil Spring Leveling Spacers (three 5/16" spacer's = 1") Part# 34932
* Coil Spring Distance Spacers 1" Part# 34854
DJM Suspensions – http://www.djmsuspension.com
* 2” Front Coil Springs Part# CS2400-2
* 3” Front Lower Control Arms Part# CA2400L-3
* 3” Steel Lowering Blocks W/ U-Bolts Part# SB2400-3
* 4” Steel Lowering Blocks W/ U-Bolts Part# SB2400-4
* 3” Replacement U-Bolt Kit Part# LBUBK
* Pinion Shim Kit 2 Degree Part# ACC2PSK
* Pinion Shim Kit 4 Degree Part# ACC4PSK
* Pinion Shim Kit 6 Degree Part# ACC6PSK
* Cal-Max SuperShox Rear Part# 2100
Clean Cut Creations - http://www.cleancutcreations.com
* Tubular Lower Crossmember Kit
* Replacement Upper and Lower Gas Tank Crossmembers
Western Chassis – http://www.sporttruckdirect.com
* 3” Front Coil Spring
Jags That Run – http://www.jagsthatrun.com
* ½” Solid Billet Lowering Block (This block can be bolted to any of there other blocks to achieve a extra ½ drop) Part# COL-504
* 1” Solid Billet Lowering Block Part# COL-501
* 2” Solid Billet Lowering Block Part# COL-502
* 3” Solid Billet Lowering Block Part# COL-503
* Heavy Duty U-Bolt Kit Part# COL-505
* Axle Pinion Shims 2, 3 and 4 Degree Shims
* Lower Replacement Crossmember Part# COL-550
AIR Lift - http://www.airliftcompany.com
* Air Lift 1000 Load Assist Rear Bag Kit Part# 59546
**Note use Air Ride Technologies bag plates for 2.5” leafs when using the Air Lift Bag kit with lowering blocks. Part# A070
AIM – http://www.truckin.com
* Billet Coil Over Shock Combo- Height Adjustable with Adjustable Damping and Rebound.
* 1"-2"-3"-4" Alloy Extruded Blocks with pinion correction angle built in and with steel pins inserted for strength. Guaranteed not to break forever.
KYB – http://www.kyb.com
* GR2 Front Part# 341374
* GR2 Rear Part# 344464
* Gas Adjust Front Part# n/a
* Gas Adjust Rear Part# 5191
Monroe – http://www.monroe.com
* Reflex Front Part# 931353
* Reflex Rear Part# 911228
Universal Suspension Parts
Belltech – http://www.belltechcorp.com
* Hexagon Button Bump Stop Kit Part# 4915
* Cone Bump Stop Kit Part# 4918
* Cone Bump Stop Kit Part# 4921
* Retangle Bump Stop Kit Part# 4900
* FOAM Cylinde Bump Stop Kit Part# 4920
* Wedge Bump Stop Kit Part# 4903
DJM - http://www.djmsuspension.com
* Round Bump Stop Kit Part# 10R
* Square Bump Stop Kit Part# 10S
Suicide Doors – http://www.suicidedoors.com
* 2.25" Bolt In C-Notch
burn is offline
post #32 of 79 (permalink) Old 03-28-2008, 02:35 AM
CALI-BOSS
DBNissan's Avatar
We can mention 355nation here
DBNissan is offline
post #33 of 79 (permalink) Old 04-14-2008, 10:45 PM
ok with a 2/3 drop is it nec to install drive shaft shims? what is the benefit/downfall from this?
BrLowRado is offline
post #34 of 79 (permalink) Old 04-14-2008, 10:49 PM
Send a message via AIM to JosueZQ8 Send a message via Yahoo to JosueZQ8
I'm not even sure what those are? LOL But no, you don't have to do anything like that......just drop it and go! :P
Josh
'04 Reg Cab ZQ8.
Formerly grounded 355 Member #59
Now, lifted Colorado club member #275
JosueZQ8 is offline
post #35 of 79 (permalink) Old 04-14-2008, 10:57 PM
ok i have the zq8 with the 17inch wheels and i put 2in springs on the front and after reading this i've learned that it only dropped the front an inch i wanna leave the springs and run either the belltech balljoints or the djm control arms but im not real sure how the controls arms will do any advice on this situation? i have the belltech leafs out back to help the ride but i kno im gonna have to block it to get it level with the front unless anyone knows of something better.
post #36 of 79 (permalink) Old 04-15-2008, 07:07 AM
I think the control arms will drop you too much. You'll have major running issues up front. The BJ's and you might be alright for a while, untill your stock shocks give out. And there's really no cure for that right now, other than Coilovers. Those new belltech shocks that came out won't stop rubbing problems so I wouldn't plan on those helping much.
Josh
'04 Reg Cab ZQ8.
JosueZQ8 is offline
post #37 of 79 (permalink) Old 04-15-2008, 11:55 AM
CALI-BOSS
DBNissan's Avatar
My QA1 adjustable coilovers set to the stiffest setting is almost like being at full lock. You'd have to hit a pretty big bump or dip to rub at that setting.
DBNissan is offline
post #38 of 79 (permalink) Old 04-17-2008, 06:22 PM
i still have a good amount of clearance up front i switched to a 245/45/17 tire and i have about 3inches of fender gap up front so if i did the BJ and the new belltech shox it would rub? hmm i dont know what im going to do then i dont really have the money for the coilovers right now but i want a decent ride and low stance....
post #39 of 79 (permalink) Old 04-17-2008, 07:12 PM
Yes, you will still rub. Like I said, don't count on the shocks to help any, if at all with rubbing issues. I just intalled them and am less than impressed. But these shocks are NOT for solving rubbing issues though so I wasn't expecting them to do so.
Josh
'04 Reg Cab ZQ8.
JosueZQ8 is offline
post #40 of 79 (permalink) Old 04-18-2008, 06:02 PM
how do you have yours slammed so low?
