Ultimate Static Drop FAQ, How To's, Part #s and Helpful Info - Page 3 - Chevy Colorado & GMC Canyon
post #41 of 79 (permalink) Old 04-26-2008, 01:56 PM
mattewrc's Avatar
Send a message via AIM to mattewrc
Re: Ultimate Static Drop FAQ, How To's, Part #s and Helpful Info
I have a z85 with a 3 inch cut coils in the front and 3 inch drop blocks in the rear......if i use the belltech ball joints and 3" drop leafs in the rear....am i going to have major problems? Will i be too low? Will i need to get "notched?" what is that and how much does that usually cost? Do i have other options? I already bottom out occasionally, id think with 3 more inches id constantly bottom out
mattewrc is offline
post #42 of 79 (permalink) Old 04-26-2008, 10:47 PM
Send a message via AIM to JosueZQ8 Send a message via Yahoo to JosueZQ8
Originally Posted by BrLowRado
how do you have yours slammed so low?
I have these shocks on there, plus the 2" balljoints. So a little more than 3" in the front. Sure it's low, but there's a price to pay in ride quality, at least with MY setup. I know there's guys out there who give these shocks rave reviews, and maybe I just have the wrong spring in there?
Like I said, these shocks will drop you an inch, but just don't expect not to have rubbing issues.
"Too Low" is just going to depend on you own personal tastes. Some guys like it slammed, some like it lowered, some just want a subtle change, etc. Looks like the setup you're thinking about would put you around 5/6 which is pretty darn low on a Z85! lol You're deffinatly gonna have rubbing issues up front and real bad axle slapping if the thing isn't already just riding on the bumpstops. C-notching is almost a given when going that low, it just makes a world of difference in ride quality. I'm not sure what the cost would be to install one but the notch itself should only be between $50-$75. Mine is custom but I still paid $50 for all the metal and for it to be cut.
If you're interested in going that low, PM rrcn on here. He's that low on a Z85 and his truck is bad freakin a s s!!!
Josh
'04 Reg Cab ZQ8.
Formerly grounded 355 Member #59
Now, lifted Colorado club member #275
JosueZQ8 is offline
post #43 of 79 (permalink) Old 05-03-2008, 11:45 AM Thread Starter
I restored the part numbers that I posted before. I will add the qa1 info and double check some of the newer part numbers real soon.
Thanks
brewer15650 is offline
post #44 of 79 (permalink) Old 05-07-2008, 05:13 PM
mattewrc's Avatar
Ok so with a z85, 3 inch coils+2 inch ball joints in the front and 3 inch drop blocks+3 inch drop leafs in the rear......throw in a 2" c-notch and a flush crossmember.........will I need shocks other than my stock ones?
mattewrc is offline
post #45 of 79 (permalink) Old 05-07-2008, 06:13 PM
I honestly don't think shocks will help. LOL You could try the Belltech Street Performance ones and see how much better it is. Those are pretty much your only option as far as replacement drop shocks.
If you notch the rear, you won't even need shocks period. I'm rocking the stock shocks out bach with my notch and there's no reason to get drop shocks because I'll never get anywhere near hitting the frame ever again! haha So the worn out stockers with 85K on them do just fine.
Josh
'04 Reg Cab ZQ8.
JosueZQ8 is offline
post #46 of 79 (permalink) Old 05-07-2008, 06:17 PM
mattewrc's Avatar
Has anyone done a write up for installing ball joints/drop leafs? Also would I need to notch anywhere else or trim my bump stops or anything?
mattewrc is offline
post #47 of 79 (permalink) Old 05-07-2008, 06:24 PM
I'm not sure on the write ups, you'll have to search around. But the install on those parts is pretty simple for anyone that's mechanically inclined. Or if you had specific questions, there are tons of people that would help ya out!
And on the bumpstops, the rears will be gone after the notch anyway LOL, but you might need to trim the fronts a little bit. Or possibly take them out all together and see how the ride is. If it's not that bad then just leave them out. I took mine out and I have tons of room under there...
Josh
'04 Reg Cab ZQ8.
JosueZQ8 is offline
post #48 of 79 (permalink) Old 05-07-2008, 06:28 PM
mattewrc's Avatar
Could I install, then notch it? Or do I have to notch before the drop? So I dont need to notch above my pumkin like that one guy did?
mattewrc is offline
post #49 of 79 (permalink) Old 05-07-2008, 06:36 PM
It doesn't matter, dealers choice! If you wait till after the drop to notch it, then you'll have to put up with the horrible ride untill you do get it notched. But if you were gonna drop it, then notch it like....the next day or so, even a week, then it wouldn't be that bad.
And I would go ahead and notch that bed brace above the pumpkin while you have the bed off, just in case. You'd be kicking yourself in the ass if you got everything all put back together only to find out that you should've notched the brace and then had to take the bed back off!! hahaha
Josh
'04 Reg Cab ZQ8.
JosueZQ8 is offline
post #50 of 79 (permalink) Old 05-07-2008, 09:02 PM
CALI-BOSS
DBNissan's Avatar
I would highly recommend new shorter shocks. Shocks not only give you ride comfort, they also give you better control and stability. Unfortunately there isn't any really good way to show you how the ride is with good shocks compared to bad shocks. Ron (The Wolf!) went for a ride in my truck and I specifically asked him to take me down the roughest roads in his area. We came up on and uneven part of the road where there was a significant drop and he said he could not go over 20 mph without bottoming out hard and bouncing. I hit it at about 45 mph and cruised over it trouble free. You can see a bunch of gouges in the road from everyone scraping. We didn't bottom out, scrape or even bounce.
DBNissan is offline
post #51 of 79 (permalink) Old 05-07-2008, 10:47 PM
mattewrc's Avatar
So which shocks do you reccomend? The qa1's?
mattewrc is offline
post #52 of 79 (permalink) Old 05-07-2008, 10:52 PM
Those are what I'd go with, but that's alot of scrilla....lol So I'm stuck with these belltech shocks for now.
Josh
'04 Reg Cab ZQ8.
JosueZQ8 is offline
post #53 of 79 (permalink) Old 05-07-2008, 11:28 PM
CALI-BOSS
DBNissan's Avatar
I had a choice between the QA1s and the Belltech coilovers. I chose the QA1s because they have adjustable dampening which will allow you to dial-in your ride. They are priced about the same as Belltech's set. However, you will have to modify your truck to accept the QA1 coilovers. It's laid out in my review.
DBNissan is offline
post #54 of 79 (permalink) Old 12-21-2008, 12:12 AM
just ordered the GroundForce 2/3 kit for my canyon, anyone have it? i had groundforce on my lightning and they rode great, but have since opted for bags and pavement.
Brent
2000 SVT Lightning, bagged on 22's, laying frame and fully shaved
2007 GMC Canyon, Daily Driver, Stock for now.
one_lo_mini is offline
post #55 of 79 (permalink) Old 01-11-2009, 02:29 PM
Why does the GroundForce kit say 5-cyl specifically? Nobody else specifies an engine with their kits. They also don't include new shocks. Isn't that a problem?
2004 Colorado Crew Cab Z85 LS, 5spd, 2.8L (daily driver)
2001 Mustang GT Coupe, Auto (weekend)
2005 Toyota Matrix Xr (wife's)
grendal is offline
post #56 of 79 (permalink) Old 01-11-2009, 02:30 PM
Next question:
Does anyone have pics of their lowered CREW cab with stock wheels still on it? I am gonna do suspension BEFORE wheels and will have to roll on the stockers for at least another year, so I'd like to see how they look.
I'll probably be rolling BFG Radial T/A tires on the stock wheels, probably 235/70-15.
Thanks,
Grendal
grendal is offline
post #57 of 79 (permalink) Old 01-11-2009, 02:43 PM
CALI-BOSS
DBNissan's Avatar
Here's mine on the stock wheels
<-- click image for lager size
DBNissan is offline
post #58 of 79 (permalink) Old 01-11-2009, 02:48 PM
Xtreme wheels don't count :)
grendal is offline
post #59 of 79 (permalink) Old 01-21-2009, 04:12 PM
the drop shocks...are they just new shocks for when you lower your truck or do they actually drop the truck?
2006 GMC Canyon ZQ8
Installed
Leer color matched tonneau cover
Pioneer D2 Double Din Head Unit
2 12" Memphis Audio S-Class Shallow mount subs
Arc Audio 300.2 Amp w/ 4ga. Wiring kit
6 1/2 inch Arc Audio coaxial door speakers
Waiting to be Installed
Fiberglass Rollpan
Gen II style front bumper
Goodmark steel 2 inch Cowl hood
3/4 inch Drop kit and C-Notch
rkramer19 is offline
post #60 of 79 (permalink) Old 01-21-2009, 05:54 PM
CALI-BOSS
DBNissan's Avatar
The Belltech 25005 0"-1" drop shocks will actually lower the front of the truck up to 1"
DBNissan is offline
