Ultimate Static Drop FAQ, How To's, Part #s and Helpful Info - Chevy Colorado & GMC Canyon
post #1 of 79 (permalink) Old 11-02-2006, 10:54 PM Thread Starter
Lowering Products
BellTech Suspensions http://www.belltechcorp.com
1” Regular Cab Front Springs P# 4201
1” Crew Cab and Ext Cab Front Springs P# 4205
2” Regular Cab Front Springs P# 4203
2” Crew Cab and Ext Cab Front Springs P# 4206
1" or 2" PRO Kit for Regular Cab P# 12203
1" or 2" PRO Kit for Crew Cab and Ext Cab P# 12206
**Pro kit #12203 consists of lowering springs, Spring Distance Spacers and Leveling Spacers.
Lowered Front Shocks with new damping technology that retains the use of the stock coil springs.
Drop Front Shock 0"/-1"/-2" P# 25005
Rear Non height Adjustable P# 22096
0-3” Front Shock Coil Over Combo Height Adjustable (Fixed Damping Galvanized) P# 12001
0-3” Front Shock Coil Over Combo Height Adjustable (Fixed Damping Galvanized) with rear shocks P# 13001
0-3” Front Shock Coil Over Combo Height Adjustable, Damping Adjustable and Stainless Steel w/ Rear Damping Shocks for use with lowering leaf springs P# 21001
0-3” Front Shock Coil Over Combo Height Adjustable, Damping Adjustable and Stainless Steel w/ Rear Damping Shocks for use with factory leaf springs P# 21003
2” Drop Ball Joints P# 2103
3” Rear Leaf Springs P# 5953
1” Lowering Blocks W/ U-Bolts P# 6010
2” Lowering Blocks W/ U-Bolts P# 6110
3” Lowering Blocks W/ U-Bolts P# 6210
Rear U-Bolt Kit With Hardware P# 6205
Pinion Shim Kit 1 Degree P# 4973
Pinion Shim Kit 2 Degree P# 4975
Pinion Shim Kit 3 Degree P# 4976
Pinion Shim Kit 4 Degree P# 4977
Pinion Shim Kit 6 Degree P# 4979
Rear Nitro-Drop Shocks 3”-5” P# 7503
Rear Nitro-Active Shocks 3”-5” P# 10503
Front Sway Bar Kit 1.25” Diameter P# 5421
Rear Sway Bar Kit 1" Diameter P# 5521
Rear Frame C-Notch P# 6603
Replacement Tranny Crossmember gain 2.25 of clearance P# 6963
Coil Spring Leveling Spacers (three 5/16" spacer's = 1") P# 34932
Coil Spring Distance Spacers 1" P# 34854
DJM Suspensions http://www.djmsuspension.com
2” Front Coil Springs P# CS2400-2
3” Front Lower Control Arms P# CA2400L-3
3” Steel Lowering Blocks W/ U-Bolts P# SB2400-3
4” Steel Lowering Blocks W/ U-Bolts P# SB2400-4
3” Replacement U-Bolt Kit P# LBUBK
Pinion Shim Kit 2 Degree P# ACC2PSK
Pinion Shim Kit 4 Degree P# ACC4PSK
Pinion Shim Kit 6 Degree P# ACC6PSK
Cal-Max SuperShox Rear P# 2100
Clean Cut Creations http://www.cleancutcreations.com
Tubular Lower Crossmember Kit
Replacement Upper and Lower Gas Tank Crossmembers
Western Chassis http://www.sporttruckdirect.com
3” Front Coil Spring
Jags That Run http://www.jagsthatrun.com
½” Solid Billet Lowering Block (This block can be bolted to any of there other blocks to achieve a extra ½ drop) P# COL-504
1” Solid Billet Lowering Block P# COL-501
2” Solid Billet Lowering Block P# COL-502
3” Solid Billet Lowering Block P# COL-503
Heavy Duty U-Bolt Kit P# COL-505
Axle Pinion Shims 2, 3 and 4 Degree Shims
Lower Replacement Crossmember P# COL-550
AIR Lift http://www.airliftcompany.com
Air Lift 1000 Load Assist Rear Bag Kit P# 59546
*Note use Air Ride Technologies bag plates for 2.5” leafs when using the Air Lift Bag kit with lowering blocks. P# A070
AIM http://www.truckin.com
Billet Coil Over Shock Combo- Height Adjustable with Adjustable Damping and Rebound.
KYB http://www.kyb.com
GR2 Front P# 341374
GR2 Rear P# 344464
Gas Adjust Front P# n/a
Gas Adjust Rear P# 5191
Monroe http://www.monroe.com
Reflex Front P# 931353
Reflex Rear P# 911228
QA1 http://www.qa1.net/
**See How To here 1st before ordering>> viewtopic.php?f=55&t=57755
Front QA1 coilovers:
DR7855P Proma Star AL single adjustable coilover shocks - $152.95 each
DDR7855P Proma Star AL double adjustable coilover shocks - $275.00 each
9029-146 4" Stud Mount Conversion - $26.10 each
7888-110 SPANNER WRENCH & THRUST BEARING KIT - $45.95
*Request bottom bushing bolt sleeve 9/16"
Rear QA1 shocks:
TC1661P Stocker Star AL single adjustable shock - $139.00 each
DTC1661P Stocker Star AL double adjustable shock - 275.00
note: above rear shocks are for ZQ8 leaf springs. Belltech drop leafs may require a shorter shock and Z85 leafs may require a longer shock, which will require the upper T-Bar mount kit. Consult Naake Racing for proper size
**Prices based from 01/2008 http://www.naake.com
Universal Suspension Parts
Belltech http://www.belltechcorp.com
Hexagon Button Bump Stop Kit P# 4915
Cone Bump Stop Kit P# 4918
Cone Bump Stop Kit P# 4921
Retangle Bump Stop Kit P# 4900
FOAM Cylinde Bump Stop Kit P# 4920
Wedge Bump Stop Kit P# 4903
DJM http://www.djmsuspension.com
Round Bump Stop Kit P# 10R
Square Bump Stop Kit P# 10S
Suicide Doors http://www.suicidedoors.com
2.25" Bolt In C-Notch
** Note Ground Force, Belltech and DJM make “Lowering Kits” consisting of a combination of parts but I am not listing the part numbers for those because you will most likely piece your suspension together.**
FAQ
More than likely you will notice that after you lower a Colorado the passenger side will sit higher than the driver’s side. You can fix this by removing a 1/2”-3/4” of a coil off the top of the passenger’s side coil spring.
Crew Cab and Ext Cab guys can use Regular Cab springs to achieve an extra 1/4" – 1/2" drop.
You can trim or remove the upper bumps stops above the leaf springs to allow for more suspension travel and a smother ride.
If you truck sits uneven in the rear you can adjust the rear leaf spring shackles forward or backwards to accommodate the difference.
The first batch of DJM A-Arms were know for bending but they have since redesigned them and are replacing the old ones at no charge as long as you bought them from an authorized DJM Dealer.
S10 lowering blocks will work if modified first. The Colorado uses a 15/32" alignment pin while an S10 uses a 9/16" diameter alignment pin. So you will have to grind them down from 15/32 to 9/16" for the blocks to work.
The Xtreme Colorado comes with same suspension as a ZQ8 but the xtreme looks lower because the fender flares hang down a 1/2” lower than zq8 flares.
Stock ZQ8 Coil Springs are 1’ lower than Z85 Coil Springs.
Stock ZQ8 Leaf Springs are 1” lower than Z85 Leaf Springs.
The ZQ8’s overall tire diameter is 1” less than a Z85’s tire diameter thus making the ZQ8 Look even lower than a Z85.
brewer15650 is offline
post #2 of 79 (permalink) Old 11-04-2006, 06:10 AM
CALI-BOSS
DBNissan's Avatar
Very nice job collecting all the data Brewer! Lemme know if you want some pics and I'll post them up in here.
~Dan
DBNissan is offline
post #3 of 79 (permalink) Old 11-22-2006, 02:21 AM
post #4 of 79 (permalink) Old 11-22-2006, 04:48 PM
didnt' get around to seeing this post, good job brewer, now if we can just get all the noobs to look here........
Grounded 355 Member #4
LiLKaRBoY13 is offline
post #5 of 79 (permalink) Old 11-26-2006, 07:01 PM
Send a message via AIM to mass835
I think it would be a good idea to compile pictures of trucks with certain drops. This way people could see if they chose this certain combination of parts, they would be able to see the turnout.
Anyone agree?
mass835 is offline
post #6 of 79 (permalink) Old 12-11-2006, 04:37 PM
Re: Ultimte Static Drop FAQ, How To's, Part #s and Helpful I
[quote="brewer15650"]Lowering Products
1β€
burn is offline
post #7 of 79 (permalink) Old 01-25-2007, 01:53 AM
Send a message via Yahoo to r_brzezowski
what colorado catalog are you talkin about?
"Au'Ryte"
r_brzezowski is offline
post #8 of 79 (permalink) Old 01-25-2007, 01:59 AM
CALI-BOSS
DBNissan's Avatar
You can request a paper catalog here
http://www.belltechcorp.com/about/get_catalog.htm
Or you can view it online
http://www.belltechcorp.com/products/gm/colorado.htm
DBNissan is offline
post #9 of 79 (permalink) Old 01-31-2007, 12:04 PM
http://www.belltechcorp.com/download/ap ... R_CANY.pdf
If you look at PDF page 3 - in step 2 it refers to the "STREET PERFORMANCE" shocks as quick reference# QR7056. Then go to PDF page 9 where you will find an index of Quick Reference numbers. It lists QR7056 as parts: 25005 / 220896
But if you look at PDF page 4 is lists the parts as 25005 / 22096
burn is offline
post #10 of 79 (permalink) Old 03-18-2007, 10:36 PM
1β€
Back in the scene, more to come...
XT_4U2NV is offline
post #11 of 79 (permalink) Old 03-19-2007, 01:35 AM
CALI-BOSS
DBNissan's Avatar
The 4203 will actually give you approximately .25" - .50" lower drop due to the extra weight of the extended cab and the ride won't be as harsh. It will fit the same.
DBNissan is offline
post #12 of 79 (permalink) Old 07-20-2007, 03:21 PM
i'm looking for a good shop in san diego area ddose anyone know about one thanks!
canyonSD is offline
post #13 of 79 (permalink) Old 07-22-2007, 02:39 PM
If you're willing to drive way up to Victorville, we can get you hooked up for a really good price. What are you looking to lower your truck with?
Grounded Member #55
My Car Domain
rrcn is offline
post #14 of 79 (permalink) Old 08-03-2007, 06:59 PM
anyone know why a lot of the lowering kits say they dont work with the ZQ8? is it the tie rod issue?
ihaveonetoo is offline
post #15 of 79 (permalink) Old 08-03-2007, 09:06 PM
CALI-BOSS
DBNissan's Avatar
It's because the ZQ8 is already lowered using drop springs from the factory. So, a 2" drop spring will lower a Z85 2" but will only lower a ZQ8 .5". The springs will fit, they just won't lower the ZQ8 much because it's already dropped a little.
DBNissan is offline
post #16 of 79 (permalink) Old 08-04-2007, 01:24 AM
makes sense, does anyone make a lowering kit for ZQ8
post #17 of 79 (permalink) Old 08-06-2007, 04:17 PM
what would be the cheapest way to lower a ZQ8 2", stock 17" wheels
post #18 of 79 (permalink) Old 08-06-2007, 05:14 PM Thread Starter
Belltech 2" ball joints with give a zq8 a true 2" drop and blocks int eh rear
post #19 of 79 (permalink) Old 08-06-2007, 05:16 PM
It's not the cheapest, but it's the best way. I don't know if you can cut the 4203's to drop you 2" on top of the 1" drop you already have because it means cutting off about 2 full loops.
Grounded Member #55
My Car Domain
rrcn is offline
post #20 of 79 (permalink) Old 08-06-2007, 07:34 PM
brewer, how much drop are you running? If you dont mind me asking, how much was it for the drop on your truck? I want mine to look similar to yours.
