Ultimate AIR RIDE FAQ, How To's, Part #s and Helpful Info - Chevy Colorado & GMC Canyon
post #1 of 27 (permalink) Old 11-03-2006, 09:29 PM Thread Starter
AIR RIDE SUSPENSIONS
Clean Cut Creations http://www.cleancutcreations.com
Tubular Lower Crossmember
Upper and Lower Gas Tank Crossmembers
Air Ride Kit: http://www.cleancutcreations.com/carinfo.html
-Tubular upper and lower front control arms
-Raised tubular transmission crossmember
-Raised tubular lower gas tank crossmember
-Tubular upper gas tank crossmember/wishbone mount
-Upper rear wishbone
-Tubular adjustable rear lower links
-Bag brackets & hardware.
Progressive Automotive http://www.progressiveautomotive.com
Front Shockwaves Air Ride Kit P# CO-TMA
Rear Air Ride Kit P# CO-TLB
http://www.progressiveautomotive.com/ARTcolorado.htm
GTC Fabrication http://www.gtcfabrication.com
Upper Gas Tank Cross-Member * Now Available
Powder Coated Canyon/Colorado Transmission Cross-member * Now Available
Rear Differential Bracket * Now Available
Rear Weld in 5-Link Air Ride Kit * Now Available
Rear Bolt in 5-Link Air Ride Kit *Not Released Yet
The kits will be a forward mounted wish-bone link set up, with the bags mounted on link bars for better lift and ride quality. I have designed the kit so that you use the factory fuel tank and also keep the EVAP system. The kit will include everything you need, including new brackets to relocate the EVAP canister, and also a gas X-member which will raise your gas tank. Both will completely lay out on 22’s.
BarnYard Customs http://www.builtbybyc.com
Upper and Lower Air Ride Control Air Sets
UNIVERSAL AIR RIDE PARTS LINKS
www.streetbeatcustoms.com Forum Sponser and all aroung good guy. Give them a call and ask for Tom. They will beat any price.
http://www.suicidedoors.com
http://www.lowriderdepot.com
http://www.fbirides.com
http://www.ridetech.com
http://www.aimind.com
I will be keeping this post up to date as new Air Suspension parts become available for the Colorado and Canyon's. If I have left something off the list please feel free to PM me and I will add it.
I will be doing a separate list for lift kits next.
brewer15650 is offline
post #2 of 27 (permalink) Old 11-03-2006, 10:27 PM
Location: When I'm king, things are gonna be different around here.
Nice!
Thanks for posting this info.
2005 Z85 2wd Crew-Cab, Black, I-5, Auto, 17-inch ZQ8 wheels.
I know Victoria's secret.
Always remember: Pillage before you burn.
Rick_crew is offline
post #3 of 27 (permalink) Old 11-03-2006, 10:32 PM Thread Starter
Your welcome!
post #4 of 27 (permalink) Old 11-04-2006, 01:03 PM
Has anyone herd about prices on these parts?
Ryn_Ott is offline
post #5 of 27 (permalink) Old 11-08-2006, 01:25 PM
Send a message via AIM to Onyx1136
You need to be a little more detail oriented next time you research something lke this. BarnYard Customs is closed, and has been for most of this year. says so very plainly on the homepage of the builtbybyc website. the owner, Mike White, has been stealing people's money and jerking them around for a few years now. just thought you might want to know so you can remove it from the post.
Ox
Onyx1136 is offline
post #6 of 27 (permalink) Old 11-12-2006, 09:24 PM Thread Starter
I posted the information to help people out, it isn't perfect but its a good start. I have heard plenty of bad stuff about byc and that they are closed but I am not going to put down a company that I haven't had any experience with. You have 37 post and your going to tell me I need to do more research.
post #7 of 27 (permalink) Old 11-12-2006, 09:53 PM
I didn't say you needed to do more research, I said u should check the details more closely. go to the BuiltbyBYC website, please. it says very plainly on the homepage, Barnyard Customs is Now Closed. you can't buy anything from BYC anymore, nor should you. so there's no point in listing a company on your post that is no longer in business and can't be purchased from. and I can bash BYC because I have done business with them in the past, and Mike White does owe me money.
and, how does post count have anything to do with how much research someone has done? if it makes you feel good that you have 700 posts and I only have 30, then I congratulate you.
I wasn't bashing you or your post. you provided alot of good information and you did a very good job. I was just trying to help you and anyone else that might waste their time trying to buy something from BYC. but, you can take the little unimportant things as personally as you want to, I suppose.
Ox
Onyx1136 is offline
post #8 of 27 (permalink) Old 11-12-2006, 10:10 PM Thread Starter
Ok cool I just spent allot of time putting that together and I was like I cant beleave he just said that. Sorry for lashing out. I will be updating it soon and Ill do something about it.
Thanks
post #9 of 27 (permalink) Old 11-17-2006, 11:36 PM
Thanks for the post. Good to know!!!
now in my fav..
supermodulation is online now
post #10 of 27 (permalink) Old 12-06-2006, 08:16 PM
Send a message via AIM to Sawblade6
i wonder what would be the best rear setup for HIGH durability and endurance?
I dont beat my truck, but its my daily driver, and i do put ALOT of miles on it going from NY to NC.
Sgt Joseph Freeman
INFILTRATE.....DESTROY.....then rebuild
3 easy concepts
***Proud Supporter of Scorched Earth Policy '07*** USMC
Grounded 355 member #45
Sawblade6 is offline
post #11 of 27 (permalink) Old 01-27-2007, 12:43 AM
a 4 link would be good for ya or even a custom 3 link wishbone
http://www.subsonickustomz.com
R.I.P. Holly Ann Lacinski, you are forever in our hearts
goinlow is offline
post #12 of 27 (permalink) Old 03-29-2007, 10:08 AM
hey brewer15650, you seem to know alot about lowering a colorado with zq8 suspension so i was wondering if you could help me out. I am thinking about bagging my truck and I don't know where to start. It will soon be lowered 2" front and 3" rear. I want to be able to lay frame on 20's with 245/35 tires. Any advice you can give me on EVERYTHING I need would be great.
'04 Colorado ZQ8
Billet Grille
1"/2" Drop
Nitro Drop 2 Socks
Gibson Exhaust
PCMfor less Tuned
S.S. Cal Vu Mirrors
20" Panther Wheels
Python Alarm/ Remote Start
bertcathey4 is offline
post #13 of 27 (permalink) Old 03-29-2007, 10:20 AM
Ask these questions in the bagged club buddy!
http://www.coloradofans.com/viewtopic.p ... &start=525
We can help you out there. :D
lancers is offline
post #14 of 27 (permalink) Old 05-04-2007, 12:46 PM Thread Starter
I updated some GTC Fabrication info
post #15 of 27 (permalink) Old 09-30-2007, 12:30 AM
does anyone have a link for a full airbag kit with compressor and everything i would need to have a airbag kit.
myfirstamericanchevy is offline
post #16 of 27 (permalink) Old 04-16-2008, 04:31 PM
Re: Ultimate AIR RIDE FAQ, How To's, Part #s and Helpful Info
i know this has been around a while but... Mini truckin put one of GTC fabs rear 5 link on a colly and did a little
walk-through looks pretty cut and dry all things being considered. the rear 5 link comes with everything
except airlines, tank, compressor and fittings.
http://www.gtcfabrication.com/catalo...x.php?cPath=21
in addition, anytime now they will be releasing a few tubular upper and lower control arm kits that will lay out on 24s.
they are uni-joint upper and lower and complete with bag and shock brackets. a little pricey at 1399.00
but very hassle-free. the only welding required is the upper bag bracket and upper shock bracket. heres the link.
http://www.gtcfabrication.com/catalo...products_id=47
06' Silver Birch Ext. Cab
99' Maroon SDime - *FOR SALE*
98' XJ Classic
78' Silver Anniversary Corvette
-Bagged 355 Member #19-
Cardomain http://www.cardomain.com/ride/2428417
erunner is offline
post #17 of 27 (permalink) Old 06-17-2008, 09:33 PM
barnyard customs went out of business back in 04 or 05...Reason i know that is cuz i bought upper A-arms from them. so no long in business...
joseln135 is offline
post #18 of 27 (permalink) Old 02-03-2009, 12:58 AM
Send a message via AIM to Sully Send a message via Yahoo to Sully
where are the How To's?
Fight my brute!!!
http://sullyzq8.mybrute.com
Sully is offline
post #19 of 27 (permalink) Old 02-20-2009, 10:36 AM
I just installed a set of bags for the back and a compressor system from AirLift... It's not a slam kit, it's a load leveler kit.
$189 for the bags - ebay.com Search for "Air Lift 59546"
$141 for the compressor kit - Jegs.com Search for 25592 (131+shipping)
Installation was super easy(as long as you have the tools, nothing complicated about it at all), and quite elegant to me. I put the pressure gauge between the hood and brake release, it's sort of a dangerous spot if I rearend enyone, for my shin. But it is easy access and fits there just fine.
My compressor wont hold air, don't bother trying to find a check valve for it, just call Air Lift and they sent me out one free. Apparently a pretty common problem. You can use the bags without the onboard compressor, heck you could even use one of those $30 tire inflators, but once you set the pressure you are stuck with it until you stop and get out and adjust it again.
One super cool feature I found was when running the air line to the back from the engine bay; The clips that hold the brake lines have one more spot available for "something else", so I just pushed the air line into the clips and didn't have to use any zip ties. I put the compressor right behind the right head light, infront of the air box. To the ley person it looks factory.
2006 Canyon SL I4/5SPD
Putco Punch Grill Insert (Denali Style)
Pioneer DEH-P835R | PolkAudio DB6500 Components | 2 JVC EXAD 6" Powered Subwoofer CS-BB2
Gentex 177 - Auto Dimming/Compass Mirror
TruckBox | BedRug bedliner | GM Spoiler and bed Rails
Air Lift Helper Bags w/ Compressor | GM Fog Lights
20% Tint | 4" Nerf Bars | 2010 16" Wheels
jasonhc73 is offline
post #20 of 27 (permalink) Old 02-20-2009, 10:49 AM
For the lifted guys:
Monroe MA764 is an airshock for the rear. Use for a 2" lift ( shackles or AAL ). Longer travel than Rancho RS5325 by .9"
rangerbob is offline
