Shackle, Torsion Bar, Front and Rear Shock Write Up (DONE) - Page 2 - Chevy Colorado & GMC Canyon
post #21 of 446 (permalink) Old 02-12-2007, 06:18 PM
Sorry I meant did Synergy supply the shackle or leaf srping bushings?
'06 Stealth Gray Canyon Z85 4x4
Coulda had a solstice, but got a Canyon!
jeepster105 is offline
post #22 of 446 (permalink) Old 02-12-2007, 07:52 PM Thread Starter
leaf spring bushings remained stock
gawillet is offline
post #23 of 446 (permalink) Old 02-19-2007, 08:59 PM
Great Job! Truck looks great.
05 Colorado Crew Cab Z71 LS
Vortec 3500 I5 4sp Auto
K&N, 3.73 Rear,Silverstar Ultra Headlights.
XM Radio,OnStar,Leather,Moonroof,Rear Slider
Drop in Liner,Husky Low Pro Toolbox,Ventshades
TB's Cranked,2" Synergy Shakles, Rancho 5K's
BFG 33x10.50 KO's
Lifted Club Member #95
PghMedic is offline
post #24 of 446 (permalink) Old 04-16-2007, 08:38 AM
Send a message via MSN to MDColorado
Why would you lift the differential to take off the weight? You need to lift the body/frame to take the weight off the springs.
MDColorado is offline
post #25 of 446 (permalink) Old 04-16-2007, 08:40 AM
My stupidity!! I skimmed through too quickly. You placed jack stands under the frame. Won't make that mistake again.... : )
post #26 of 446 (permalink) Old 04-16-2007, 01:02 PM Thread Starter
Thanks for the free bump!
Their's been a lot of question lately that can be answered in this writeup.
gawillet is offline
post #27 of 446 (permalink) Old 06-12-2007, 01:30 AM
Now I understand how the shackles are put into place. Future mod in the making soon.
2006 Chevrolet Colorado, 4X4, Crew Cab, 3.5L, Victory Red, K&N 63 Series Intake, Skidz
jetpilot is offline
post #28 of 446 (permalink) Old 08-22-2007, 09:12 PM
Great MMP write-up!
I have added your mod to the "Suspension How-To’s":
cFans.com How-to (MMP) Index
http://www.coloradofans.com/forum/viewtopic.php?t=28472
Thanks,
SuperModulation
post #29 of 446 (permalink) Old 08-22-2007, 10:00 PM Thread Starter
Originally Posted by supermodulation
Great MMP write-up!
Thanks,
SuperModulation
Nice!
Glad I could help out :)
gawillet is offline
post #30 of 446 (permalink) Old 08-23-2007, 12:53 AM
I agree -- this is a pretty good write-up. Just in time for me to replace shocks and shackles when I get back from the slope in couple months!
'06 Z-71 Crew Cab -- Sold.
'12 5.3 LT2 - Wicked.
hmmbagodden is offline
post #31 of 446 (permalink) Old 09-12-2007, 08:54 AM
gawillet, I know you've already read it a thousand times but this is a great write up. Thanks to you, a mod I was really unsure about doing myself was finished in less than two hours.
2006 Canyon Z71 SLT, I5, 2WD, Ext Cab, Silver Birch Metallic
Bridgestone Dueler AT Revos
Weather Tech floor liners, ProTecta bed mat, GM bed rail and tailgate caps
Bubaloo Shackles and TB crank
Husak is offline
post #32 of 446 (permalink) Old 09-12-2007, 09:00 AM Thread Starter
You're welcome, glad I could help!
Congrats on the lift!
gawillet is offline
post #33 of 446 (permalink) Old 09-12-2007, 09:23 AM
Canyon08Z71's Avatar
Originally Posted by ulmerc
My question - does the Z71 come with a longer stock shocks than the Z85? If so, we need to make a note that you would need 5190's for a Z71, or 5301's for a Z85.
Here is a photo of the OEM Z71 KYB rear shock VS Rancho RS5190.
Canyon08Z71 is offline
post #34 of 446 (permalink) Old 09-12-2007, 11:47 AM
So just a quick question about the TB cranking (that I haven't found anywhere on here)... I gave mine 5 turns on the pass side and 5-1/2 on the drivers side to take out the "Chevy lean." With settling, it is giving me just over 1.5 inches of lift (I wanted to keep the rake), but even with the very first turn the bolt it was pretty hard to crank. I'm no beast, but I can usually put some pretty good torque on wrenches, so it kind of worried me. Is it normal for them to be pretty stiff??? And yes, I did have the front up on Jack stands. Thanks in advance.
Husak is offline
post #35 of 446 (permalink) Old 09-12-2007, 12:45 PM
Yes they are difficult to turn - you are adjusting a HUGE spring. Most of us jack the truck up to remove the weight from it. Otherwise it's much harder to turn and you run the risk of stripping the adjuster bolt.
rangerbob is offline
post #36 of 446 (permalink) Old 09-12-2007, 01:06 PM
Thanks rangerbob, that's what I was hoping. I knew it would be tough if it was on the ground, but I wasn't sure about when it was off the ground.
Husak is offline
post #37 of 446 (permalink) Old 09-12-2007, 01:18 PM
Yeah - I used a 1/2" x 12" ratchet and it was very hard. I almost busted out the 24 or 36" breaker bar but I wanted to make sure I kept count of the turns. :D
post #38 of 446 (permalink) Old 09-12-2007, 05:16 PM
I used a breaker bar to do mine and it was hard.
RIP Spike 9-25-2007
coyote is offline
post #39 of 446 (permalink) Old 09-12-2007, 05:44 PM Thread Starter
I sprayed WD40 on the bolts the night before and before I started the rear end. When it came time to crank the torsion bar bolts they moved with ease. With the front tires off the ground a typical size socket wrench worked fine. The little adjusting I did when the truck was on the ground to get it level took a little elbow grease, but a socket wrench with no extension was able to turn them.
gawillet is offline
post #40 of 446 (permalink) Old 09-12-2007, 06:16 PM
So you sprayed your TB bolts too? Hmm. I sprayed all of the rear ones, but didn't think about spraying those.
Husak is offline
