Shackle, Torsion Bar, Front and Rear Shock Write Up (DONE) - Page 3 - Chevy Colorado & GMC Canyon
post #41 of 446 (permalink) Old 09-12-2007, 07:36 PM
Send a message via AIM to Andersonn
Do you have to get new shocks for the front?
Andersonn is offline
post #42 of 446 (permalink) Old 09-12-2007, 07:37 PM
No you don't.
RIP Spike 9-25-2007
coyote is offline
post #43 of 446 (permalink) Old 09-12-2007, 07:44 PM
Cool.
What about the rear?
post #44 of 446 (permalink) Old 09-12-2007, 08:11 PM
You don't have to but most do. If you go offroading or over extended the rear suspension you run the risk of blowing a shock out.
RIP Spike 9-25-2007
coyote is offline
post #45 of 446 (permalink) Old 09-13-2007, 12:09 PM
thanks for the info i am getting ready to crank the tb.s to level out the truck
2006 colorado I5 crew cab 4x4 Z71
Fire 2505 is offline
post #46 of 446 (permalink) Old 09-15-2007, 02:16 AM
Send a message via AIM to orangebangZ71
how much lift did those shackles give you. and i was wondering if you can do me a favor and measure the distance from hole to hole (center) on the shackles. im about to make a set. thanks
04 sunburst orange metallic 3.5L I5 4.11
K&N FIPK, mickey thompson MTZ 315/75/16, rock cralwer street locs 152, wolo air horns
IRONWORKERS LOCAL 433
orangebangZ71 is offline
post #47 of 446 (permalink) Old 09-15-2007, 12:22 PM
Hole to hole your shackles need to be 8 inches for 2 inches of lift over stock.
rangerbob is offline
post #48 of 446 (permalink) Old 09-20-2007, 01:07 AM
i have an add a leaf and want to change it to just shackles. i have the 4" skyjacker suspension lift. so for me to get it even with the front i would need to make the hole to hole on the shackles 12"
post #49 of 446 (permalink) Old 09-20-2007, 11:17 AM
i'll trade you my shackles for your AAL. :D
post #50 of 446 (permalink) Old 09-29-2007, 06:52 PM
Send a message via MSN to 06_rado
Will this lift allow 32's to go under it without rubbing??
Lifted#145
TOTW Winner#41
06_rado is offline
post #51 of 446 (permalink) Old 09-29-2007, 10:42 PM Thread Starter
For a Z71, 32's won't rub at all, I'm running 32x11.5. 33x10.5 will also fit. I'm 99% sure Z85 should be just fine especially with 2 inches of lift.
gawillet is offline
post #52 of 446 (permalink) Old 09-30-2007, 09:25 AM
sweet cuz I just put some 32x11.5 yesterday and theyre rubbing like a son of a b. lol.
One more question where did you get the shackles from??
Lifted#145
TOTW Winner#41
06_rado is offline
post #53 of 446 (permalink) Old 09-30-2007, 11:15 AM
Try this palce. I got mine a month ago shipped and all for $169. RS5190 for the rear and RS5300 for the front.
Poor Mans Lift:
BFG AT's 32x11.5x15
Bubaloo Shackles/TB Crank
Rancho 5300/5190 Shocks
Dif Drop
Extang Tonneau
Lifted Club Member #146
ohcyspRado is offline
post #54 of 446 (permalink) Old 10-04-2007, 02:34 AM
you have a 2" shackle my AAL is for 4"
post #55 of 446 (permalink) Old 10-04-2007, 09:11 AM
Canyon08Z71's Avatar
The add a leaf is only 2.5" of lift...
Canyon08Z71 is offline
post #56 of 446 (permalink) Old 10-04-2007, 10:48 AM
^^^ What he said.
post #57 of 446 (permalink) Old 10-04-2007, 12:47 PM
Send a message via AIM to J-man67
Great write-up man! This should help just about anyone!!
GET IT DIRTY!!!!!
2004 Colorado Ext cab LS z71 4x4 - traded :(
2007 Harley D. FXDB (Street Bob)
2006 Kawasaki KFX400
2004 Kawasaki zx636R
J-man67 is offline
post #58 of 446 (permalink) Old 10-06-2007, 03:28 AM
Just used this write up to put bubbaloo's shackles and RS 5190s on.
Quick note, but all the shackle bolts and bottom shock bolts were 13/16", not 3/4". I pulled the 3/4" socket out, was confused on why it didn't fit and then grabbed the 13/16" socket to find it fit perfectly... btw, it's a 2006 Crew Z71, if that might start making a difference?
And 06_Rado, when we meet up on Sunday, you can take a look at the shackles/TB, and see that 32s will have no problem... Or, you could swap tires with me, let me drive around with them for a season or two, and then I can tell you first hand how they work...
'06 Z-71 Crew Cab -- Sold.
'12 5.3 LT2 - Wicked.
hmmbagodden is offline
post #59 of 446 (permalink) Old 10-06-2007, 11:14 AM
The shackle & lower shock nuts and bolts are 21mm.
post #60 of 446 (permalink) Old 10-06-2007, 12:36 PM
Yup. Agree with Canyon. Rear Shackle and lower bolts on the shocks are 21mm. The front shock lower bolt is 15mm... And the top nut was different than listed as well. I can't off hand remember what size wrench I used though. Either way, this writeup helped me alot. I had never done shocks or anything with suspension before, and I got er done.. Well........... hours later....
05 Colorado - I5 3.5L Z71
AEM Brute Force Cold Air Intake - Custom Catback Exhaust
Fold-A-Cover Hard Tonneau Cover - HPTuners -
2" Shackle/TB Lift - Kenwood CD/MP3/CD-R/CD-RW Head Unit - Infinity Reference Series 6 1/2" Speakers - Performance Headlights - 48" Fire Stix LED Tailgate Lights
FIREJKP22 is offline
