How-To: Install Leaf Spring Helpers if interested(With Pics) - Chevy Colorado & GMC Canyon
post #1 of 16 (permalink) Old 02-14-2007, 06:17 PM Thread Starter
Well, I didnt' know if anyone was interested, but I have recently got my hands on a set of leaf spring helpers, and the instructions are to choppy, I decided to do a little research on how to install them....
After a Long time of searching and googling, i didn't find a how to, but I saw someone explain how he put them on to help out as "traction Bars", so with some of his explaination, I set off to do it myself seeing as no one here has done a install on these...These are relatively cheap to try if anyone is wondering, the cost around 25-30 dollars from any auto parts store and help out in traction, the reason I got them was because of all the wheelhop I had....
Tools...I needed a 19MM deep socket, a 14MM socket, and a 14 MM wrench..
Here are the materials that all come in the box...
1st of all, you have to find a place to put them on to...I found a place to install them, I didn't want them to touch anything but the leaf springs, so I put them about an inch from the shock mounting plate....
2nd, one I have an idea of where I want them to sit, I hook one side up and put the screw that comes with the kit to hold it up on one side..
3rd, I pick up the rear and slide the u-bolts through the little plate that comes with the kit, slide the washer through it, and loosely bolt them in place, I did the same with both sides...and now the spring should sit almost where you want them to sit...
4th I set it where I want it to be, make sure it doesn't touch anything else, and tighten the front bolts with the wrench on one side and the ratchet on the other side...after I tighten in down from botch sides, they have a bolt that should sit in the middle of the screw, turn that one the opposite direction, so they can sandwich the bracket with the two bolts..
5th with the 19mm, I recheck the alignment, center the helpers to the leafs, and tighten them up all the way...
Lastly, I double check every bolt is tight, and that it doesn't interfere with any other parts, and do the exact same to the other side...and KABAAM!!!
ur finished
this is the finished view of how they sit on my truck...
and here are some more pics of the truck because I feel like it HAHA
I'm not sure if this is needed, but I figured, since the instructions confused the living beans out of me, I might as well let the guys know how to install them as these are inexpensive ways to improve your traction....oh, by the way...........
speedbumps here I come
any more questions, feel free to ask away.
Jorge
Grounded 355 Member #4
LiLKaRBoY13 is offline
post #2 of 16 (permalink) Old 02-14-2007, 06:23 PM
Send a message via AIM to ImRickJamesBitch Send a message via MSN to ImRickJamesBitch Send a message via Yahoo to ImRickJamesBitch
arent spring helpers supposed to go on top of the spring.. ya know, to help it?
- Justin
Lifted Club Member #104
MY CARDOMAIN PAGE
ImRickJamesBitch is offline
post #3 of 16 (permalink) Old 02-14-2007, 06:24 PM
actually those ones look like they go below... i retract me previous statement.
- J
MY CARDOMAIN PAGE
post #4 of 16 (permalink) Old 02-14-2007, 07:49 PM
Did they eliminate any wheel hop?
Conservative Club Member #35
My Gallery
jlong is offline
post #5 of 16 (permalink) Old 02-14-2007, 08:49 PM
Send a message via AIM to C6U6I6H
that seems like the question...
and i'd like to see PROOF!!!
that means a sold burnout without and skips or chirps!!! hahaha
Bagged 355 Member #1, Join The Club Here!!!
C6U6I6H is offline
post #6 of 16 (permalink) Old 02-14-2007, 09:28 PM Thread Starter
I just got through doing a test drive, they eliminated about I'm sure 85-90% of my wheelhop...I used to get wheelhop all of first and some of second...now I can roast all of first and some of second, when I starts catching traction tho it does hop JUST A LITTLE....so that's a BIG Improvement, because I can turn a corner, stomp it, and go sideways!!!! that's great because I used to be able to do that along with getting a feeling my bed was about to fly off.....for 25-30 dollars, there's not much you can do to beat it.... O yea, I don't have a camera to get a nice roast...I still have my sisters digital camera from when I went to the Houston meet a month ago...LOL, so no vids...
post #7 of 16 (permalink) Old 02-14-2007, 09:50 PM
sounds good!!!
C6U6I6H is offline
post #8 of 16 (permalink) Old 02-14-2007, 10:41 PM
nice
2005 Rado Z71 Ext Cab I5
Vent Visors | Redline Hood Lift Kit
2"shackles/TBar lift/Skyjacker Nitro 8k's
Diff Drop 3/4" | Pro-Comp AT's | 1" BL soon
Lifted Club Member #80
Gun Toting American Club Member #34
JeSuS is offline
post #9 of 16 (permalink) Old 02-14-2007, 11:10 PM
Send a message via Yahoo to draggin_az
how are those speed bumps treating you?
06 Z85: ext cab : white
billit grille : debadged
20% tint : various interior
pieces painted :baked head lights
4 banger baby: 3/4 drop
20'' pacer wheels
draggin_az is offline
post #10 of 16 (permalink) Old 02-14-2007, 11:50 PM
LiLKaRBoY13,
What kind of drop do you have on your truck???
2005 Colorado Victory Red Z85/ZQ8
2005 Ford Escape 4x2 XLT
http://www.cardomain.com/ride/2579322/1
victoryred05 is offline
post #11 of 16 (permalink) Old 02-15-2007, 02:01 AM Thread Starter
I have a z85 with a 2/3 drop, with a whole coil cut off of one, and a coil and a half cut off the other side, rides surprisingly smooth....
post #12 of 16 (permalink) Old 02-15-2007, 10:18 AM
Wow, that looks good. I can't to get my 2/3 installed
soon.
post #13 of 16 (permalink) Old 03-02-2007, 03:46 PM
SoRAD's Avatar
correct me if im wrong, but dont the directions say to mount behind and close to the rear axle? a friend of mine is running these and thats how he has them set up. or will it make a difference?
On the road to bagging the canyon
http://www.soradstunts.com
SoRAD is offline
post #14 of 16 (permalink) Old 03-02-2007, 04:12 PM Thread Starter
yea, it said to mount them behind the axle, if you are using them as helpers, I asked around, and when you burn out, the front of the leaf is what twists the worse, so putting them in the front will help you out a lot more with traction....
post #15 of 16 (permalink) Old 03-03-2007, 04:11 PM
how much were they?
and the rear is lowered with 3" blocks then right? and stock 235/50-17 zq8 tires?
traded in:
2006 Black RC Z85 I4 M5
traded in:
2008 Carbon Black Metallic Ext Cab Z85 Canyon 3.7L
Now:
2008 RC Sierra Black 4.8L
twopoint8 is offline
post #16 of 16 (permalink) Old 03-03-2007, 05:13 PM
Send a message via AIM to sillyoldtayo
yah i should get those prolly haha my lakewood Tbars are only like 1.5" off thr ground at the front haha but no wheelhop I only have 1" blocks to
TOTW #25...SWEEEEETRUCK!
sillyoldtayo is offline
