lowering 06 colorado extreme.. please help!!! - Chevy Colorado & GMC Canyon
post #1 of 17 (permalink) Old 03-13-2009, 08:02 PM Thread Starter
hey guys i found this kit on ebay.. please let me kno what u guys think
http://cgi.ebay.com/ebaymotors/CANYON-C ... ccessories
what i basically want is the fender to be right on top of the tire. any little piece of advice/information will help thank you guys
i want a drop sort of like this
ep312acer is offline
post #2 of 17 (permalink) Old 03-13-2009, 08:16 PM
Re: lowering 06 colorado extreme.. please help!!!
Lowering an xtreme with that kit I think your going to be having lots a rubbing issues up front for sure. My ZQ8 rubs enough with the additional 2" Belltech drop (balljoints & blocks). Your axle will likely be sitting on the frame unless you c-notch it as well.
Keep in mind the XTREME flares are larger and hang down lower than the ZQ8 flare.
NVR2LOW & THE 2 LOW CREW (Wife, Son & Daughter)
2007 Chevrolet Colorado Crew Cab ZQ8
2" Belltech Drop Ball Joints, 2" Belltech Drop Blocks
Bedrug liner, Checkmate FX Tonneau Cover
GM premium molded carpet floor mats
Canyon & Colorado club of Canada ( member #7 )
NVR2LOW is offline
post #3 of 17 (permalink) Old 03-14-2009, 07:05 AM Thread Starter
so0o a 3/4 drop is to low?!?!
post #4 of 17 (permalink) Old 03-14-2009, 09:19 AM
Send a message via AIM to xtreme07colorado
on a xtreme i would say so unless you wanna notch the frame in the rear and bang the fuck outta your fenders on the front.
mine with a 2/3 sittin on 20s
Winner TOTW #1 2008
Winner TOTW #3 2009
xtreme07colorado is offline
post #5 of 17 (permalink) Old 03-15-2009, 05:47 AM Thread Starter
u think mine would sit like that on the 18 inch rims?!? im not changing the rims........... but anyways if i do decide to go with the 2/3 instead of the 3/4 which kit will i be better off with?!?
http://cgi.ebay.com/ebaymotors/Ground-F ... ccessories
one more thing... what kind of drop do u think the yellow truck i posted the picture of up top has?!? wild guess.......
post #6 of 17 (permalink) Old 03-15-2009, 10:18 AM
its 3/4 you are already 1/2 i would suggest the bell tech pro kit for the front and blocks for the back. the kit also comes with 1/4 spacers to take care of chevy lean.
The Wolf! QA1 Rydahs!
Click HERE to see SinSity Kustomz Productz
The Wolf! is offline
post #7 of 17 (permalink) Old 03-15-2009, 01:39 PM
CALI-BOSS
DBNissan's Avatar
I'm rollin 2.25"/3" on mine when the rear helper bags are aired down and very minimal rubbing on the stock tires or my 255.35.20
I'm running QA1 adjustable coilover up front and JTR 2" blocks in the rear.
The Ground Force kit would be a better way to go but will only drop the front an inch since the Xtreme already has the ZQ8 1" drop spring from the factory.
To get another inch using that kit you will need to get the Belltech 1" drop shocks.
DBNissan is offline
post #8 of 17 (permalink) Old 03-16-2009, 11:15 PM Thread Starter
ok so what kit do i finally go with?!? lol im new to the truck scene so dont really kno how everything works............ i just want the truck to be slammed
post #9 of 17 (permalink) Old 03-16-2009, 11:32 PM
it depends on the budget. from what i can get outta what you posted, you wanna drop 2/2 or 2/3. you could go with bjs and blocks by belltech or 2'' lowering springs with 1'' drop shocks up front and blocks in the back also all made by belltech. the upper end stuff would be the coilovers either by QA1 or Belltech. i would stay away from the belltech drop leafs. i hear they are way too soft. you will probly need a low profile tranny crossmember and a c notch. those along with coilovers and youll be set.
Winner TOTW #1 2008
Winner TOTW #3 2009
post #10 of 17 (permalink) Old 04-10-2009, 02:33 PM
I went with the 2" drop ball joints and 3" blocks from belltech and I think its perfect. The way I did it probably isn't as smooth as the way dbnissan did it but it was definately cheaper.
zachwright1 is offline
post #11 of 17 (permalink) Old 04-10-2009, 05:06 PM
Send a message via AIM to 02specv
I don't see how you guys can ride on a 2/3 drop on an xtreme. I have 4203's up front and 2" blocks in the back and it slaps the frame very frequently. The front bottoms out a good bit too, but not nearly as bad as the back. It looks good tho.
05 Victory Red Colorado Xtreme Crewcab
02specv is offline
post #12 of 17 (permalink) Old 04-10-2009, 05:35 PM
those control arms wont work with a z71 right?
the only way to lower a z71 is the TBs right?
'05 crew cab z71 canyon
Lifted Club Member #256
Audio:
jvc kw-avx810 with ipod cable, alpine spr-17's all around, alpine pdx-5,
uts sub box with 2 8" boston subs ------FOR SALE, PM if interested
Misc:
viper 5900 alarm w/ remote start, painted interior to match,
tinted tails and 3rd brake light, 20% front tint and 35% rear tint,
3" suspension maxx keys and 2.5 " aal
Future Mods:
pro comp 18's, ddm HIDs, supermod interior light and DRLs,
mbrp cool duals, k&n cold air intake, painted mirrors and handles to match
canyon_fan91 is offline
post #13 of 17 (permalink) Old 04-11-2009, 06:30 AM
Wrayzor's Avatar
Send a message via Yahoo to Wrayzor
Running the same set-up and love it. I had to cut rear bump stops to reduce rear slap some.
2006 Xtreme CC
Kenwood Excelon DNX-9140 w/iTouch
Pioneer Premier 6 1/2s in doors, Pioneer tweeters
De-Badged and Belltech 1.5"/2" Drop
If you like it Stock, you're easily amused!
Grounded 355Member #13
TOTW 2007-10
Wrayzor is offline
post #14 of 17 (permalink) Old 04-11-2009, 01:05 PM
It must be because mine is an extended cab and both of yours are crew cabs.
post #15 of 17 (permalink) Old 06-21-2009, 06:39 AM
Whos truck is the yellow crew cab xtreme? Love the drop setup youve got, can you tell me what kit or parts you used to get that look? Does the ride feel almost or similar to stock? whta does de-bagged mean and what does that do? Is it true the exteme is already lowered 1"? does that mean you dropped your truck only a 1/2 inch?
808bronco is offline
post #16 of 17 (permalink) Old 06-21-2009, 10:33 AM
All of that was answered in the post I made...but to answer it again belltech 4203 springs and 2" blocks.
Yes. No. The truck is already 1" lower, so if you use a 2" lowering sring(which is for a z85) you'll get a little bit more than an inch.
02specv is offline
post #17 of 17 (permalink) Old 09-29-2016, 05:41 AM
Hi; I want to change my 2006 Extended Cab Colrados appearance with a body kit ,what is the best kit to go with Fiberglass or Polly & what brand (s) do you suggest ? My truck has already been lowered 2". Thanks in advance for any Help/Suggestions . David
golf*outside is offline
