Suspension Maxx Needs You! (Updated: 14 July w/New Pics) - Chevy Colorado & GMC Canyon
post #1 of 141 (permalink) Old 05-05-2009, 10:33 AM Thread Starter
Suspension Maxx http://www.suspensionmaxx.com is a Saginaw, Michigan based company that specializes in lift products for Chevy, Dodge, Ford, and Toyota trucks. I recently installed their torsion bar key kit on my Colly. I've also spent some time talking to the Suspension Maxx tech, Larry, with regards to more products for the Twins.
1. I told Larry when we raise the rear of our trucks with AALs or shackles, we resort to buying longer shocks. So would SM be interested in making 'shock extenders' at an affordable price to save members some money. He replied "Yes" and asked me to send him pics of the rear shock mounting so he could work on fabrication.
2. Next, I brought up the fact about how the members with 2WD coil spring front suspension resort to using Tacoma spacers to lift the front.
Would SM be willing to make a spacer specifically for us? Again the answer is "Yes". But Larry needs to know: A) does the Tacoma spacer sit on the coil spring or does it sit on the top strut mount? He has both spacer prototypes but would like to tailor the spacer to your desires.
B) is the Tacoma spacer a direct fit or are you guys having to do any kind of mods to it to make it work?
Any details you could give me would be great, to include pics.
Based on your input he will make the final design changes. Note: as mentioned earlier, SM is located in Saginaw, Michigan. Once he is ready for a test fit, Larry would like for a member in the general area to bring their 2WD coil spring Canyon/Colly in for the install. If interested, let me know and I will get you in contact with Larry.
Lastly, he said he will give a 10% discount to any member who is in the U.S. military. I'm going to ask him to extend the discount to those of you who give your time to public service, i.e.: EMT, firefighter, law enforcement.
Catalog
ssgjurista is online now
post #2 of 141 (permalink) Old 05-05-2009, 12:11 PM
naskie18's Avatar
Re: Suspension Maxx needs your help!
I assume he'd be looking for a stock truck to test the products rather than someone who already has a lift, correct?
naskie18 is offline
post #3 of 141 (permalink) Old 05-05-2009, 12:22 PM Thread Starter
A stock truck would be ideal. As far as a lifted truck, it would depend on the front lift. If the upper strut mount wasn't modified in any way. Rear shock mount shouldn't be any different regardless.
post #4 of 141 (permalink) Old 05-05-2009, 12:24 PM
The 2-2.5 tacoma spacers go on top of the coil-over assembly. they are not spring distance spacers.
The problem is, members that use the spacer have to cut a very small notch out of the bump-stop mount for the coil-over to fit right.
Belltech makes a 1" spring "distance" spacer.
A combination of the above would be better for a production Kit
If i were Suspension Maxx i would make a 1" tacoma spacer and also include a 1" spring distance spacer. That way you are only moving the coil-over down 0.60" thus not needing to cut anything. So 2" could be easily made with easy bolt ons. They could then include some shims for the ball-joints maybe, and a bump-stop spacer.
---DDM 10k HIDs, K&N 63series, Flowmaster, Custom Tune, E-fan, Reflexxion Cobra hood---
---07' Z85 4x2 CST lift---
--------32x10.5 Nitto Terra Grapplers on Ultra Mako Black 16x8s, MaxAir shocks, 1" BL--------
zuschke is offline
post #5 of 141 (permalink) Old 05-05-2009, 12:58 PM Thread Starter
Thanks for the info, zuschke. :D I think Larry could easily fabricate a notch in the strut spacer to accomodate the bump stop mount.
Then a member wouldn't need to mess with the spring itself. But I will pass all the comments on to him.
post #6 of 141 (permalink) Old 05-05-2009, 03:48 PM
its actually a notch in the bump stop mount on the frame(near the bottom of the shock mount). So a 2" strut spacer by itself would require this. But a 1" strut spacer and a 1" spring spacer would not.
zuschke is offline
post #7 of 141 (permalink) Old 05-06-2009, 11:04 AM Thread Starter
Bump.
post #8 of 141 (permalink) Old 05-08-2009, 01:05 PM
Send a message via MSN to M_O_Z
I take it though don't make full on suspension kits then?
Full Time Student To UTI in Glendale Heights, IL
TOTW #33 2008
2004 Chevy Colorado LS Ext Cab Z71 4x4 I5 Auto
Aftermarket sunroof, C.R. Lawrence rear sliding window,
Goodmark Cowl Induction Hood, Cooper Discoverer S/T 31X10.5R15,
K&N 57 FIPK intake, MRBP Cool Duals rear exit, Dual High/Low Beam mod,
Resonator gutted cause I was bored
Mud Club Member #27
Signed: Channing Kraemer :D
+ '06 Kawasaki KLX250S
+ '01 Kawasaki Praire 300 4x4
+ '93 Arctic Cat Lynx
+ '04 Cannondale Jekyll 600
\\19 Years Old//
M_O_Z is offline
post #9 of 141 (permalink) Old 05-13-2009, 09:36 PM Thread Starter
Re: Suspension Maxx needs your help! (Update)
Thanks to zushke and others for their input. :D Suspension Maxx is going to make a kit with a spacer for the strut assembly and a spacer for the spring. Will allow for 2" of lift without having to modify the bumpstop mount.
post #10 of 141 (permalink) Old 05-13-2009, 09:44 PM
what about the rear shock extenders, any word on that?
'05 crew cab z71 canyon
Lifted Club Member #256
Audio:
jvc kw-avx810 with ipod cable, alpine spr-17's all around, alpine pdx-5,
uts sub box with 2 8" boston subs ------FOR SALE, PM if interested
Misc:
viper 5900 alarm w/ remote start, painted interior to match,
tinted tails and 3rd brake light, 20% front tint and 35% rear tint,
3" suspension maxx keys and 2.5 " aal
Future Mods:
pro comp 18's, ddm HIDs, supermod interior light and DRLs,
mbrp cool duals, k&n cold air intake, painted mirrors and handles to match
canyon_fan91 is offline
post #11 of 141 (permalink) Old 05-13-2009, 09:46 PM Thread Starter
Patience grasshopper. Coming soon to a CFans near you. :D
post #12 of 141 (permalink) Old 05-13-2009, 10:04 PM
ahhh thank you master scott.
Audio:
Misc:
Future Mods:
post #13 of 141 (permalink) Old 05-13-2009, 10:22 PM Thread Starter
^^^^^^That's Jack of all Trades and Master of None.
post #14 of 141 (permalink) Old 05-13-2009, 10:38 PM
I am mistaken and corrected.
Audio:
Misc:
Future Mods:
post #15 of 141 (permalink) Old 05-15-2009, 12:41 PM Thread Starter
Re: Suspension Maxx needs your help! (We Have a Volunteer!)
bobandcar has volunteered to install Suspension Maxx's prototype kit for the coil spring suspension. Hopefully he will post up pics of the install. Suspension Maxx plans to use his critique of the kit and install to make any necessary design changes.
Thanks Robert! :D
post #16 of 141 (permalink) Old 05-19-2009, 07:02 PM
I want something free!! Hmmm.....tell em to make me up a pre runner style front bumper! Ill install it! I WILL!
No seriously though...this is cool. Cant wait for pics. Im curious to see what it looks like becuase the TB key kit looks A+
Lifted Club Member #179
TOTW Winner Week #31 2008
Gun Toting American Club Member #55
CAI, Gutted Cat, Magnaflow, PCMforless Tune, New Head! (Thanks GM), Supermod PTB, Vette Servo
2" TB Crank, BJ flip w/1/4" Spacer, 2" Procomp AAL, Air Shocks, 1" BL
**SINSITY KUSTOMZ**
jrbyers96 is offline
post #17 of 141 (permalink) Old 05-19-2009, 10:15 PM Thread Starter
I always keep you guys in mind. :D No homo.
post #18 of 141 (permalink) Old 05-20-2009, 12:13 PM
I wouldn't mind, but two problems though. 1) I'm prior navy, 2) I'm in TX!!
2015 Laser Blue Chevy Colorado Z71 Crew Cab
HOOK 'EM HORNS!!!!!! DA BEARS!!!!! GO NAVY!!!!!
Current mods:
Cobra 29 NW ST LE - Francis 5 1/2FT Fiberglass antenna
Yeasu FT8800 - CometZ780 Dual Band Antenna
Mudflaps w/ Chevy Logo
Cargo Rack
Shadowstarz is offline
post #19 of 141 (permalink) Old 05-20-2009, 02:07 PM Thread Starter
What do either of those two things have to do with volunteering?
Wait......you volunteered at least once.
post #20 of 141 (permalink) Old 05-21-2009, 12:35 AM
:D
Current mods:
Cargo Rack
