Tire and wheel size? - Chevy Colorado & GMC Canyon
post #1 of 6 (permalink) Old 05-07-2016, 12:22 PM Thread Starter
I have a 2004 Chevy Colorado Z71 2wd. I would like to get 32x11.5r15 tires but I am not sure if they will fit on the stock rim size. Does anyone know if they will fit?
ball4racing is offline
post #2 of 6 (permalink) Old 05-07-2016, 02:54 PM
They will rub on a stock truck on stock wheels.
Keep in mind, the truck has been around for 12 years now. Plenty of people have tried.
Take some time to review the forum.
265/75-16 is max I'd go with. It's a little bigger than stock, and most importantly, fit.
Good luck.
Thread moved into suspension area.
post #3 of 6 (permalink) Old 05-07-2016, 06:35 PM Thread Starter
Do you think they would still scrub if I raised the front end with a tb crank?
post #4 of 6 (permalink) Old 05-07-2016, 07:59 PM
Factory wheels, most likely.
11.5" wide is max. You could get lucky. Sometiems yes, sometimes no.
I say just don't do it. But it's your truck and if you don't mind it possibly rubbing a little then go for it.
Others should take over from here. I can't give more help.
post #5 of 6 (permalink) Old 05-07-2016, 07:59 PM
Yep... Will probably rub sway bar. TB crank pulls the wheels and tires inward towards the frame
GregDAP is offline
post #6 of 6 (permalink) Old 05-08-2016, 07:07 PM Thread Starter
Thanks for the help
