Rancho Lift - Chevy Colorado & GMC Canyon
post #1 of 11 (permalink) Old 07-17-2016, 01:22 PM Thread Starter
Rancho Lift
I know it's possible to put a rancho 4inch lift over a rough country leveling kit for an 05 canyon and I was wondering if anyone out there has done this and could tell me exactly how to go about this
Chris99whaley is offline
post #2 of 11 (permalink) Old 07-18-2016, 12:29 PM
Install the rancho kit. Then install the rough country leveling kit.
GregDAP is offline
post #3 of 11 (permalink) Old 07-19-2016, 07:09 AM Thread Starter
Ok. But the leveling kit attaches to the truck. Wouldn't the lift mess that up?
post #4 of 11 (permalink) Old 07-19-2016, 09:43 AM
Attaches to the truck? What do you mean? Post a link to the leveling kit. It should just be some re indexed torsion bar keys or torsion bar key spacers. All lift kits attach to the truck in some way.
How much lift are you trying to achieve? What size tires are you trying to run? And what is your budget?
GregDAP is offline
post #5 of 11 (permalink) Old 07-19-2016, 10:59 PM Thread Starter
http://www.roughcountry.com/gm-suspe...FYVbhgod1fwEIg
No budget. However much is fine.
At some point 33x12s
I attached a picture. Kind of want it like his. He has a 4 inch rancho and the same leveling kit. Wondering how he did it
post #6 of 11 (permalink) Old 07-20-2016, 01:39 AM
My guess is he installed the rancho kit... then install the torsion key spacers and used longer lift shackles in the rear and/or installed add a leafs.
I have the rancho kit on my truck in the front along g with the torsion bars cranked a little for another inch of lift. In the back I have the rancho lift shackles and 2" add a leafs so it looks more level. I'm running 33x11.5 tires on rims with 4.5" of backspace. If you want 12" wide tires I would get rims with around 4" of backspace
GregDAP is offline
post #7 of 11 (permalink) Old 07-20-2016, 01:25 PM Thread Starter
Alright. Thank you. And does it nose dive/ rake any?
post #8 of 11 (permalink) Old 07-20-2016, 05:44 PM
No it sits pretty level maybe a tad higher in front but not noticeable unless you break out the tape measure. Keep in mind you can only lift the rear about 3.5"-4" after that you run into drive shaft length problems.
GregDAP is offline
post #9 of 11 (permalink) Old 07-20-2016, 10:40 PM Thread Starter
Alright. Appreciate it
post #10 of 11 (permalink) Old 07-20-2016, 10:46 PM Thread Starter
Do you have any time you recommend?
post #11 of 11 (permalink) Old 07-20-2016, 11:38 PM
Time??? What do you mean?
GregDAP is offline
