Guide to lowering - Page 2 - Chevy Colorado & GMC Canyon
post #21 of 147 (permalink) Old 01-17-2007, 03:43 PM
i have a quick question. i bought my base model colorado (06 z85) in august 06. i was wanting to know if anyone has used the djm 3/4 kit. i also want to know how the alignment checked out when the job was completed. also do you use all the factory parts? thanx for the info.
cmcagle1980 is offline
post #22 of 147 (permalink) Old 01-27-2007, 12:45 AM
you will need an alignment, before I bagged my truck I at the 3/4 drop on mine and to me it wasn't low enough but hey the from on the ground isn't low enough for me. I will say this the ride quality did not chnage form stock to the djm kit.
http://www.subsonickustomz.com
R.I.P. Holly Ann Lacinski, you are forever in our hearts
goinlow is offline
post #23 of 147 (permalink) Old 01-27-2007, 01:44 PM
THANX FOR THE INFO. TOM @ STREETBEATCUSTOMS.COM SOLD ME ON THE BELLTECH KIT. WAITING ON AN INSURANCE CHECK NOW.
post #24 of 147 (permalink) Old 03-25-2007, 02:04 PM
Stealth_Canyon's Avatar
Send a message via Yahoo to Stealth_Canyon
I just bought the DJM 3/4 kit and was wondering if I will also need to buy a pinion shim kit. If so which one? Can anyone help me with this one? I also bought the DJM shocks for the rear. Do I also need to change out my front ones. Right now I am in Iraq and buying the parts and when I get home I will install them so I am not sure how the control arms are designed.
Stealth_Canyon is offline
post #25 of 147 (permalink) Old 05-03-2007, 11:16 PM
Send a message via AIM to bigredmini
Why the Hell would you lower a truck?
1992 Nissan Truck - 3" Lift - 31" BFG's - NISMO/Flowmaster/K&N Stuff
Black 2005 Chevy Colorado Z71 Crew Cab- 31" BFG Mud Terrains - 3" Flowmaster Super 40 Series
bigredmini is offline
post #26 of 147 (permalink) Old 05-03-2007, 11:35 PM
CALI-BOSS
DBNissan's Avatar
So I can reach my gear in the middle of my work truck's bed
DBNissan is offline
post #27 of 147 (permalink) Old 05-07-2007, 10:27 AM
Because all the kidz are doing it, it's fun
DRRAAGGG IT!!!!!
one2blower is offline
post #28 of 147 (permalink) Old 05-20-2007, 05:22 AM
Send a message via MSN to Victim of Corruption
dotn no how old this post is but it was sent to me via a link.
that yellow circled nut u are talkin about has a allen key hole in the end of it. put a ring spanner on her and then stick in the allen key. she wont keep turnin then and u can get it back nice and tight.
------- BAGGED355 member #13- LAYIN HARD SILL-------------- WATCH THIS SPACE!!!
Victim of Corruption is offline
post #29 of 147 (permalink) Old 06-19-2007, 06:11 PM
Send a message via AIM to 06blckbeauty
can someone go more into depth on the first pic about lining everything up??
now for sale. pm me for info
http://www.cardomain.com/ride/2842418
06blckbeauty is offline
post #30 of 147 (permalink) Old 06-19-2007, 11:49 PM
CALI-BOSS
DBNissan's Avatar
The top has 3 bolts. You want to make sure the one of the bolts lines-up with the side of the lower shock bolt eyelet. That way when you reinstall it it goes in much easier.
DBNissan is offline
post #31 of 147 (permalink) Old 06-19-2007, 11:56 PM
oh so its not a have to or die situation? it just makes things go smoother??
how long on avg did it take u guys to do this???
also which is the better shox to get nitro drop or nitro active?
post #32 of 147 (permalink) Old 06-20-2007, 12:13 AM
CALI-BOSS
DBNissan's Avatar
Yes, it will make reassembly much easier because you won't have to fight the spring tension to twist it. To disassemble/reassemble the front will take about 2 hours for a seasoned tech.
Not sure on the shocks as I have not run either of them.
DBNissan is offline
post #33 of 147 (permalink) Old 06-20-2007, 05:30 PM
what shocks are you running then??
post #34 of 147 (permalink) Old 06-20-2007, 08:12 PM
CALI-BOSS
DBNissan's Avatar
I have the DJM Calmax shocks. They would be too stiff if you run with an empty bed though.
DBNissan is offline
post #35 of 147 (permalink) Old 06-20-2007, 08:23 PM
well i bought the kit with the nitro active shox. be here in 5-6 business days
post #36 of 147 (permalink) Old 06-26-2007, 11:49 PM
Send a message via AIM to Stewman29 Send a message via MSN to Stewman29
i'm planning on using 2" spindles in the front and 3" leafs in the back with airshocks so i can pump it up when i need to haul my bike around... anyone know of any problems I'd run into doing that?
Stewman29 is offline
post #37 of 147 (permalink) Old 07-20-2007, 05:20 PM
i went 3in blocks in the back on a 2007 canyon zq8 and it on the bump stop what could i do to help this out and have a little cleaner ride
canyonSD is offline
post #38 of 147 (permalink) Old 07-20-2007, 06:37 PM
canyonSD is offline
post #39 of 147 (permalink) Old 08-09-2007, 06:13 PM
cut the bump stop.
post #40 of 147 (permalink) Old 08-17-2007, 09:27 PM
anybody know what size socket to take off the top bolt on the shock??
nevermind. little to much to drink!!!
