biggest tires on a stock colorado ? - Chevy Colorado & GMC Canyon
post #1 of 11 (permalink) Old 08-19-2009, 12:59 PM Thread Starter
what is the biggest tires i could put on my z71 ?
no lift are anything
i have 31s im thinking i could put 32s
kumho mud terrain is the tires im getting
t.sedlock is offline
post #2 of 11 (permalink) Old 08-19-2009, 03:29 PM
2004CrewCab's Avatar
Re: biggest tires on a stock colorado ?
You can put 32s. Just check and make sure that the tires are not rubbing against anything. Sometimes it happens and sometimes it doesn't.
2004 CrewCab purchased 07/19/04, sold 04/21/12.
Now down to one 355. The 07 Regular Cab.
2004CrewCab is offline
post #3 of 11 (permalink) Old 08-19-2009, 06:04 PM
Coyotekart63's Avatar
Send a message via AIM to Coyotekart63
32 x 11.5? 32x12.5? im looking for new tires too and woudl really like to know this as well.
2005 Z71 CC RWD
Lifted Colorado Club Member #272
Cooper Discoverer STT 32x11.50x15
Skyjacker 2.5" AAL
Rancho RS5190s(soon to be all the way around)
Big time TB Crank
Stock Bedliner Wheels
Coyotekart63 is offline
post #4 of 11 (permalink) Old 08-19-2009, 11:33 PM
CanyonAB's Avatar
You need a 2" lift to run 32x11.5 ... 32.10.5 might work.
1964 Chevy Impala Convertible, mostly stock, 90,000 miles
2005 GMC Canyon CC 3.5L Offroad 4x4, lots of mods
http://canada355.com
-Branden
"Stupidity is like nuclear power...it can be used for good or evil...and you don't want to get any on you"
CanyonAB is offline
post #5 of 11 (permalink) Old 08-20-2009, 07:19 AM
BahamaTodd's Avatar
Send a message via AIM to BahamaTodd Send a message via MSN to BahamaTodd
Mud terrains usually run slightly larger with their larger tread, so you're pretty much stuck at 31s with no lift if you want absolutely no rub.
2004 GMC Canyon SLE Ext Cab Z71 4x4 I5 Auto
33x10.5x15 BFG AT, TB Crank, 2" Shackles, Aluminum Skidz
Gallery - Cardomain - Florida355 - Florida355 Facebook
BahamaTodd is offline
post #6 of 11 (permalink) Old 08-20-2009, 09:39 AM
So the rear shackle lift and a TB adjustment and I could run 32x11.5x15?
2005 Z71 CC RWD
Skyjacker 2.5" AAL
Big time TB Crank
post #7 of 11 (permalink) Old 08-20-2009, 03:44 PM
It should yes.
post #8 of 11 (permalink) Old 08-20-2009, 04:46 PM
BahamaTodd's Avatar
You don't need shackles. You could fit 35s back there right now if you wanted.
post #9 of 11 (permalink) Old 08-20-2009, 05:41 PM
CanyonAB's Avatar
Yeah...the clearance issues are in the front because the wheels have to turn...the back is never a concern...but it does look dumb if you crank the TB's to fit bigger tires and don't do shackles to level the back to the front.
-Branden
CanyonAB is offline
post #10 of 11 (permalink) Old 08-20-2009, 06:20 PM
BahamaTodd's Avatar
A few cranks will level the truck. My setup keeps the forward rake. Then there's those that put on shackles and max out their TBs in an attempt to level the truck.
33s, TB crank, stock shackles:
viewtopic.php?f=3&t=75235
