285 tires and 16 inch wheels on a stock canyon - Chevy Colorado & GMC Canyon
Old 02-01-2011, 04:55 AM   #1 (permalink)
Default 285 tires and 16 inch wheels on a stock canyon
Buddy of mine has a set of 285/75/R16 KM2's with black pro comp wheels he's trying to get rid of.
The question is could I tuck them on my 2008 GMC Canyon Z71 2WD?
I have a TB crank with a 2 inch lowering block in the rear, can be taken off if needed however.
Also I'm new to the whole wheel thing. These are 16 inch, 6x5.5 with 0 backspacin is what he is tellin me.
I dont know how backspacin works but I'm pretty sure my stock wheels are 6x139.7 and dont know if you could use wheels that are 6x5.5?
Thanks for your help.
doodle153 is offline   Reply With Quote Quick reply to this message
Old 02-01-2011, 05:16 AM   #2 (permalink)
Default Re: 285 tires and 16 inch wheels on a stock canyon
0 backspacing?? maybe offset? but its gonna take at 2inches of lift, and then most likely will rub, will most likely need a body lift to...and some trimming.......not sure but are u lowered? dont understand why u have the block?
And A Few Mods...
Koda22 is offline   Reply With Quote Quick reply to this message
Old 02-01-2011, 05:23 AM   #3 (permalink)
yea went the easy way out on raising and lowerin honestly. At first I just put a lowerin block on and the truck sat pretty level, but now i raised the torsion bars its higher in the front so I didnt have to buy lifts and stuff.
I just didnt know if Icould get away with putting 285 tires on stock.
Old 02-01-2011, 05:29 AM   #4 (permalink)
no not stock....but if u dont mind a little rubbing, just buy a set of shackles, or an aal for the back and crank ur tbs for 2inches....and be done...
And A Few Mods...
Old 02-01-2011, 05:31 AM   #5 (permalink)
whats the best place to buy shackles or aal? and how hard are they to put in?
Old 02-01-2011, 05:34 AM   #6 (permalink)
shackels are easy, just 2 bolts on each side.....and i would get them from suspensionmaxx.com....u will get a discount for being on this forum....or maybe the nation not sure which, maybe both......but go sign up on 355nation.net just to be safe...
And A Few Mods...
Old 02-01-2011, 05:37 AM   #7 (permalink)
alright ill check that out.
So basically if I take my lowerin block off and put shackles on and do my TB crank I should be able to tuck them with a little bit of scrubbin?
Old 02-01-2011, 09:41 AM   #8 (permalink)
i've got 285s with 16 inch rims but i'm running a 4' suspension lift from tuff country. on the bright side, no scrubbing at all tho it is more expensive
VOTE IN THE COLORADO FANS RIDE OF THE MONTH CONTEST
http://coloradofans.com/forums/102-c...er-2011-a.html
05 Colorado Z71 I5 4wd
4" Tuff Country Suspension Lift-2" shackle kit. 3.5" tb crank, .25 BJ Flip w/spacer 3" PA Body lift
LT315/75/r16 Nitto Terra Graps
16" Moto Metal wheels
K&N FIPK intake
Custom Thrush Glasspack exhaust w/chrome Bowtie Tip
Aries OffRoad Bull Bar
6000k HIDS
Mud Club #32
Lifted Club 431
05ColoradoHambone is offline   Reply With Quote Quick reply to this message
Old 02-01-2011, 11:40 AM   #9 (permalink)
yea ur gonna rub, but if its a good deal i would just deal with it.....and then down the road maybe add a body lift, or some kind of more lift...
And A Few Mods...
Old 02-01-2011, 03:52 PM   #10 (permalink)
well there the tires and wheels for $1000 but instead of doing that, Ive thought about doing my own thing.
Maybe gettin my own set of wheels and tires, maybe just some 15x8 with 31s or somethin.
How would you tell about offset and backspacin for wheels?
