Look in the suspensions thread...there are lifts galore in there.
33's and comfortably in the same sentence don't go together. It's a big challenge for 33's. You can get 33x10.5 to clear with less effort.
Check the suspension threads, it's inthere. Trust me. If you run a full suspension lift I think you need to tack on a body lift or turn up the torsion bars.
Most affordable isn't something we can help you with. That depends on how much money you have to work with. A suspension lift runs around $1300. Then you'll need wheels to meet the manufacturer specs to clear the new spindle, or spacers. If you go with a full suspension lift, don't cheap out on spacers.
Torsion bar and body lift may get you there. One of the biggest problems is the tire will hit the body mount.
That's also discussed in the threads, you'll find when you search more deeply.
