Lifting the Colorado! - Page 2 - Chevy Colorado & GMC Canyon
Old 06-30-2012, 04:02 AM   #11 (permalink)
Default
fabtech makes 3" spindels for coil spring
PerformanceLifts.com -- Fabtech Colorado & Canyon 3" Spindle Lift
or cst makes 5"
PerformanceLifts.com -- CST 2004-2010 Colorado & Canyon 5" Lift - Coil Spring Models
google is your friend
GregDAP is offline   Reply With Quote
Old 07-24-2012, 01:01 AM   #12 (permalink)
Default
anyone hear anything good or bad about MaxTrac? I found a 2" rear shackles and 3" Front Spindles for a decent price. If I do go this route am I able to add on 2.5 Coil Spacers to the front? I don't know what I could add in the back to lift the rear more.. help a newbie on lifting out?
yohyoh is offline   Reply With Quote
Old 07-24-2012, 08:07 AM   #13 (permalink)
Default
I've never heard of them. Yes you can use coil spacers with spindles.
For the rear you can use an add a leaf with the shackles. Or do a spring over axle conversion for 5 and a half to 6 inches of lift
Old 07-24-2012, 08:23 AM   #14 (permalink)
fitsector's Avatar
Default
I had that SST kit from Ready Lift installed on my 2WD back on 2009, really increases the ride height to a similar Z71 4x4, I was able to fit 30" tires there on stock rims.
Before Lift
After lift:
Current (only back shackles):
The only problem I had was related with some washers supplied that goes directly to the bottom arm, those things weared terrible fast!. After 3 months my front suspension got a lot of rattles and weird sounds (like if something was loosen). 3 visits to the suspension shop, nothing was loose, just those washers with a noticeable deformation and wear. (I followed the instructions with absolutely precision, and the kit was installed in a professional suspension shop)
I ended taking the front lift out and keep the rear shackles. (love the high stance on back and down stance in front).
In brief, I had no luck with that kit.
Proud owner of American Pickup trucks since 2006
2009 1LT Crewcab Z85 2.9 L4 2WD Deep Red
Magnaflow performance catback exhaust
Underground hard tonneau Cover
2012 2LT Crewcab Z71 3.7 L5 4x4 Navy Blue
Still stock, mods about to come!
fitsector is offline   Reply With Quote
Old 07-24-2012, 09:02 PM   #15 (permalink)
Default
I can't say you will or won't, but you might run into alignment issues running the lift spindle and the strut spacer. I had to get longer upper control arms to be able to align my truck, but I'm running the 5" CST spindle and a 2.5" strut spacer, not the 3" spindle.
I'm a responsible adult, whenever something goes wrong, I'm responsible.
CUZICAN is offline   Reply With Quote
You may not post new threads
You may not post replies
