Skyjacker 4" Lift Wheel/Tire Question - Chevy Colorado & GMC Canyon
Old 06-28-2012, 04:24 PM   #1 (permalink)
Default Skyjacker 4" Lift Wheel/Tire Question
2010 Z71 Rado 4x4
Ok so I've been doing a ton of research on here the past couple of days and i'm looking for a little help. I'm having issue with understanding the backspacing of the wheel set up I'd like to get.
From what I understand with the Skyjacker kit you can go up to a 4.75 in backspacing? Is that correct? I guess what's throwing me in the negative offset numbers versus the inches.
The wheels I'm looking at getting are here and they come in a -6 offset. Which if I'm correct would not work right? Any limitations on width of the wheel itself?
Bunker Wheels - American Outlaw Bunker Rims
Also curious as to how wide of a tire I could fit while avoiding any rubbing issues.
Thank you guys!
bigmak45 is offline   Reply With Quote
Old 06-28-2012, 08:52 PM   #2 (permalink)
08Canyon's Avatar
Default
Offset is directly based on the size of the wheel. Backspacing is measured from the inside of the wheel.
A 4.75" backspaced wheel is always going to be the same. The offset starts at the center of a wheel. So a -6 on an 8" wheel is different than a -6 on a 10" wheel.
If they wheels you are looking at specify the backspace, just use that number.
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
The Skyjacker site should list what tire size fits. Probably a 265 width tire which is 10.4". Or find an inch tire that is 10.5. Skyjacker knows what fits, go by their recommendation.
Old 06-29-2012, 12:02 PM   #3 (permalink)
Default
Awesome! Thank you so much for the help. One last question. I know thanks to this website that doing a TB crank brings the tires in closer to the vehicle. Would an approx 2" crank on top of the 4" skyjacker lift affect the width of the tire that would fit? I.e. would I need a smaller tire in terms of width with the crank?
Thanks again!
Old 06-29-2012, 03:25 PM   #4 (permalink)
08Canyon's Avatar
Default
I personally can't say for sure, but I don't believe it would. The wheel specification is mostly due to clearing the spindle and that should not be affected. The manufacturer will also list a tire size that won't rub on parts. If you as a user are okay with rubbing at lock you can run what you want. I run 265's no problem with TB crank. Running a suspension lift would not alter that (I believe).
Old 07-06-2012, 06:36 PM   #5 (permalink)
Default
hey im not sure if you have done it or not its a bit late of a reply but i just joined. i just got myself a set of 15" rims for my truck and they are sitting on 31's that look pretty beastly. try checking out visionwheels.com i believe it was. and check out the warrior's. thats what i put up
SuperJester is offline   Reply With Quote
You may not post new threads
You may not post replies
