Xtreme suspension issue... with pics - Chevy Colorado & GMC Canyon
Old 07-26-2012, 10:33 PM   #1 (permalink)
Default Xtreme suspension issue... with pics
I purchased this 2006 Colorado Xtreme / ZQ8 the other day. I love it and am excited to be a member of this forum.
The truck was lowered prior to me purchasing it. The main problem is how stiff the suspension is. It feels like there is none at all. Rolling slowly over a speed bum creates a huge thump when the back end gets over it. Not to mention any little bumps in the road. The previous owner said he got it dropped at Les Schwab. I stopped by there for an opinion. He said it should be fairly easy to switch back to the factory parts, although I'm not sure exactly what I need. Maybe I could keep it at the height is now but somehow have a more forgiving suspension.
Not sure if this is enough details but any help, suggestions, or opinions are much appreciated.
Mr Morgan is offline   Reply With Quote
Old 07-27-2012, 04:01 AM   #2 (permalink)
Triniboi's Avatar
Default
If you lived closer I would swap you my stock ZQ8 suspension because I'm looking to go lower....lol hehehe
  • 2004 Colorado zQ8 Crew Cab LS
  • Gutted Cat
  • Homemade CAI
  • Fiberglass Topper
  • 8000k HID (fogs as well)
Triniboi is offline   Reply With Quote
Old 07-27-2012, 07:45 AM   #3 (permalink)
Default
Check the bump stops first. In the second photo the front looks a little close. I think it should be about 1/2 inch. They can be trimmed. Some guys just remove them but I think that may cause unwanted metal to metal contact.
cart7881 is online now   Reply With Quote
Old 07-27-2012, 08:01 PM   #4 (permalink)
Default
The front really isnt that stiff... the back is where all the stiffness is. Does everybody with a lowered car deal with this?
Old 07-30-2012, 04:46 PM   #5 (permalink)
Default
Sounds to me like you are slapping the frame in the back. You can remove the bumpstops to give you some extra room. This is what many members on here do. Another option is to notch the frame. I slap all the time. Its the price you pay for looking good :)
Brian
2006 Extended Cab Colorado Z85
Summit White, I4, 5 Speed, Street Pack
DJM 3"/4" Drop, Belltech Street Performance Front Shocks
20" Boss 313
Kenwood DPX-301, Infinity Reference 6.5's
Alpine 10" Type R with Alpine MRP-M500 Amp, Homemade between the jump seats box
Shorty Antenna, Silverstar Ultra Headlights and Fogs, Homemade intake
bbarry24 is offline   Reply With Quote
Old 07-30-2012, 10:17 PM   #6 (permalink)
Going UP!
Send a message via AIM to blurred
Default
With it being that low and it's that rough, I am going to assume that a frame notch wasn't done and you will either need to lift it back up or notch...
blurred is offline   Reply With Quote
Old 07-31-2012, 12:11 AM   #7 (permalink)
Default
Appreciate the info guys. Don't know how to notch, or how to remove the block (cant even see it) so ill look into it. I guess as long as its not bad for the truck, i'm okay living with the stiff ride cause it does look gooood. Thanks again.
Old 07-31-2012, 12:23 AM   #8 (permalink)
Default
Guess I coulda done 5 minutes of research first... notching seems like a lot of work, and expensive. The bumpstops are in plain sight once I knew where to look. Feel kinda stupid. Maybe 2in of space between the axle and bumpstop. It is only a half inch thick at the most, so def metal on metal if it was gone.
Old 07-31-2012, 01:07 PM   #9 (permalink)
Default
Your can always buy new bumpstops. I have considered this. Belltech makes a set that is much smaller than than stock ones. I think they give you at least an extra inch of clearance.
Brian
20" Boss 313
You may not post new threads
You may not post replies
