It is currently Thu Sep 02, 2010 4:33 pm
Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2  Next
Fitting 35" tires & CST Lift & Skyjacker lift questions
Author Message
 Post subject: Fitting 35" tires & CST Lift & Skyjacker lift questions
User avatar
Colorado Fan
Im going to get 35x12.5 R18 Nitto Mud Grapplers with 18x9 with bolt pattern 6x5.5 Wheels. I'm going to get a 4" Skyjacker Lift with a 3" BL. Will I be able to fit my 35's without rubbing, slight trimming maybe? Or do I need to go with the CST to be able to clear? And is my tire/wheel combination correct? Making sure so that I don't do something wrong :).
(This is for my new Truck)
Selling old one :cry:
_________________
2005 Chevy Colorado-Z71-I5
3 Inch Body Lift
34 Inch Maxxis Bighorn Mud Terrains
17 Inch Eagle-offroad alloy
Duel Flowmasters
LIFTED COLORADO CLUB #171
 Profile
PostPosted: Sat Jan 03, 2009 5:41 pm
 Post subject: Re: Fitting 35" tires
User avatar
Colorado Fan
Is this too hard to answer? lol
_________________
3 Inch Body Lift
Duel Flowmasters
 Profile
PostPosted: Wed Jan 07, 2009 4:29 pm
User avatar
Colorado Fan
i have the 4in skyjacker and 3in body lift i run 35" toyos with 16" rims the only place i rub is during tight turning and it rubs on the cab mount in the rear of the wheelwell, its a simple fix i'd say about an hour of grinding i've just been to lazy, hope that helps
_________________
Go Big Or Go Home!
 Profile
PostPosted: Wed Jan 07, 2009 4:40 pm
User avatar
Colorado Fan
Yea it does, and you dont rub on anything when you go over bumps or up hills at first? And what if I had the money for the CST 5" 4wd kit? Should I just go ahead and grab that so I dont have to worry about rubbing really? And having 8" on my colly would be freakin sweet IMO :mrgreen: . The thing is, I don't need a brushgaurd yet, but I will have money left over after the tires/wheels and lifts to get tinted windows and a system, I am leaning towards the CST though.
Has anyone gotten it through a store yet? I know its $1,899.00 but how much is it shipped? And how much do retailers/4-wheel-shops sell them for?
I can also get the skyjacker lift with skid plate and 4 shocks for $1,500.
Dilemma Dilemma :clueless .
_________________
3 Inch Body Lift
Duel Flowmasters
 Profile
PostPosted: Wed Jan 07, 2009 5:00 pm
User avatar
2009 SESM COORDINATOR
2007 GMC Canyon Z71
How wide are your wheels? What about your backspacing? Did you decrease your backspacing to kick the wheels out a little more? It is critical that Ryan get the right wheels. Backspacing will also depend on the width of your wheel. I apparently relied too much on the well know shop I bought my parts from and did not triple check their numbers. Backspacing did not push the tires out far enough and ended up cutting them down. They put me in new tires but would not correct the wheels so I ended up stuck. Waiting for the tires to wear before I upsize to the 35s. For the short period I had them on the truck, I recall a slight rub on the middle of the wheel well and MAJOR rubbing on the body mount but I am sure that was because the wheel was tucked too far in the wheel well.
Grinding? WTF? Are the body mounts not hollow? I plan on doing this but expected that I would have to weld plates over the expected holes.
Ryan, check the CTS very closely. I looked into those and recall needing to buy many extras that were either included or much more affordable with Skyjacker.
_________________
Steve
2007 GMC Canyon Z71-4x4 Crew Cab | 3.7 I5 - Auto | 4" Skyjacker suspension lift | 3" Performance Accessories body lift | 33x11.5x17 tires (going 35x12.5x17) | 3.73 gears | Custom blurred grille | 57 K&N | BPi VS | AMS EaAU 6081 | SSK MAF Adapter | NGK AFX w/ NTK WBO2 | HP Tuner Pro wideband tuned by ME! | AMSoil fluids FTW!
Image............2010 SESM Oct 22-24 Details Here
 Profile
PostPosted: Wed Jan 07, 2009 7:13 pm
 Post subject: Re: Fitting 35" tires & CST Lift & Skyjacker lift questions
User avatar
Colorado Fan
Tire
* 35X12.50R18 ,Mud Grappler
* Load Range = 3
* Max Load = 3420
* Tread Depth = 21/32
* Overall Diameter = 35.0 inches
* Black SideWall
Wheel
* 18x9, 6 on 5.5 Bolt Pattern
* Backspace = 5in.
* Max Load = 2200lbs
* Finish = Gloss Black w/ Accents
* Hub Centric = No
* Offset = 0mm
What lift should I go for then to work with backspace, etc. I will put on spacers if I have to also.
I was also thinking about CST and BL though for more clearance on the tires so that I dont have to worry about rubbing really.
If this will work easy with the Skyjacker and BL then I will def. do that to save money.
_________________
3 Inch Body Lift
Duel Flowmasters
 Profile
PostPosted: Wed Jan 07, 2009 11:04 pm
User avatar
Colorado Fan
No rubbing on bumps or hills just sharp turns like parking and such, i don't know much about CST i'm sure its a good setup all i can say is that i have 40k on my 06 and no problems, 8" would be sweet, it all depends on what your using it for, i do alot of off-roading so my setup works for what i do, good luck i can't wait to see pics
_________________
Go Big Or Go Home!
 Profile
PostPosted: Wed Jan 07, 2009 11:21 pm
User avatar
Colorado Fan
i didn't change the backspacing, my tires are 315/75/16s, as for the grinding i wasn't going to take that much off cause i don't think i have to to solve the problem, if it did come down to welding plates over the wholes of course i'd do that plus painting for looks
_________________
Go Big Or Go Home!
 Profile
PostPosted: Wed Jan 07, 2009 11:28 pm
User avatar
2007 GMC Canyon Z71
Ryanhizzle wrote:
Tire
* Load Range = 3
* Max Load = 3420
* Black SideWall
Wheel
* Backspace = 5in.
* Hub Centric = No
* Offset = 0mm
Have no knowledge of the CST lift. But from my experience cutting down a set of tires with the 4" skyjacker lift, I personally needed 4" back spacing to fit most 35x12.5s and 3.75" to fit all 35x12.5s. Trucks will differ slightly between the same year and possibly more between years but it sounds like you would need 1" - 1.25" spacers. You may need to grind the studs down if you go with the 1" spacers and you wheels do not have a recess in them to except the stud extending out past the spacer.
_________________
Steve
 Profile
PostPosted: Thu Jan 08, 2009 7:17 am
User avatar
Colorado Fan
Yea, I figured you needed spacers. Usually thats the case when you go wider and bigger tires than what people normally do IMO. Yea, I think im going to go with the Skyjacker and BL lifts, I wanted to see if there was any problems and I guess theres not. To me the extra $500 for 1" extra of lift isnt worth it, I can use it for other good causes in my truck :). Thanks guys!!
I'll repost on here with pics when I get all the things on(idk how long that will be :clueless )! Thanks for your inputs.
_________________
3 Inch Body Lift
Duel Flowmasters
 Profile
PostPosted: Thu Jan 08, 2009 3:20 pm
User avatar
Colorado Fan
So I just found out the cost of getting my lifts done and tires on, etc. $700 flat labor with me bringing in the stuff, pretty sweet, it was usually $500-600 for suspensions and $500 for body lifts. Now all I gotta do is sell my truck and then buy this other one, woot woot. Pics will come as soon as I get it. Thanks for the opinions. BTW I'm going with 35x12.50x18 nitto grapplers with 18x9 wheels(Procomps or motos), Backspacing 4.75"-5"(depending on rim) and I will be adding spacers to help with the backspacing.
_________________
3 Inch Body Lift
Duel Flowmasters
 Profile
PostPosted: Mon Jan 12, 2009 8:32 pm
User avatar
Colorado Fan
2004 Chevrolet Colorado Z71
With that much backspacing from the rims already you shouldn't need a spacer at all to give you enough clearance because there should be enough already.
_________________
Full Time Student To UTI in Glendale Heights, IL
TOTW #33 2008
2004 Chevy Colorado LS Ext Cab Z71 4x4 I5 Auto
Aftermarket sunroof, C.R. Lawrence rear sliding window,
Goodmark Cowl Induction Hood, Cooper Discoverer S/T 31X10.5R15,
K&N 57 FIPK intake, MRBP Cool Duals rear exit, Dual High/Low Beam mod,
Resonator gutted cause I was bored
Mud Club Member #27
Signed: Channing Kraemer :D
+ '06 Kawasaki KLX250S
+ '01 Kawasaki Praire 300 4x4
+ '93 Arctic Cat Lynx
+ '04 Cannondale Jekyll 600
\\19 Years Old//
 Profile
PostPosted: Wed Jan 21, 2009 3:51 pm
User avatar
Colorado Z71 Owner
Colorado Z71 Owner
what kinda BS are you running on your setup. i got 35s on mine but i forgot what BS i got and im plannin on getting new rims. i think i got 4.25
_________________
04 sunburst orange metallic 3.5L I5 4.11
K&N FIPK, mickey thompson MTZ 315/75/16, rock cralwer street locs 152, wolo air horns
IRONWORKERS LOCAL 433
 Profile
PostPosted: Thu Feb 05, 2009 7:22 pm
User avatar
Colorado Z71 Owner
Colorado Z71 Owner
M_O_Z, you're thinking upside-down man. More backspacing will move the wheel and tire further inboard and cause rubbing on the upper ball joint, body mounts, and maybe other places as well. What he needs is less backspacing to move the wheel and tire further outboard. A spacer will accomplish this. Both Rancho and Skyjacker call for 4.5" BS on a 285 wide tire. He's talking about a 315 wide. He'll definitely need less BS to make it work. I'm running a 305 with 3.625" BS and only have about 1/2" between the sidewall and the upper ball joint. The best answer is to get the right wheel to begin with. a 3.75" BS would probably work well, but I don't know what's available in an 18".
_________________
2007 TOTW #33 - LIFTED CLUB #24 - CONSERVATIVE CLUB #43
Rancho 4" / Skyjacker Softride / PA 3" - ProComp Xterrain 305/70R16 - 16x8 Eagle 1378
Smittybilt XRC-8 Winch - Optima Red - Hella 4000 Compact Fogs - AEM / PCMForLess - E-fan - Hard Cover
 Profile
PostPosted: Sat Feb 07, 2009 4:10 am
User avatar
2007 GMC Canyon Z71
Skyjacker literature calls for 4.75" backspacing maximum:
http://www.skyjacker.com/image/catalog/ ... 0chart.pdf
_________________
Steve
 Profile
PostPosted: Sat Feb 07, 2009 8:49 am
User avatar
Colorado Z71 Owner
Colorado Z71 Owner
You're right. My bad. :oops: That's what I get for relying on my failing memory. :lol: The point is the same though. :wink:
_________________
 Profile
PostPosted: Mon Feb 09, 2009 2:29 am
User avatar
Colorado Fan
2006 Chevrolet Colorado Z71
sooo what does this mean for the 315 tire? Skyjacker doesn't recomend that size of tire does the mackspacing stay the same? I know that a bigger BS would be no good but how aboutt a smaller one? I was thinking 3.5" BS. I'm also trying to fit 35x12.5, plus i'm in Guam. Ordering stuff is too exspensive to guess on....
_________________
2006 Chevy Colorado Z71 Crew Cab
Westin Sportsman Brush Guard
4" Sky Jacker Suspension Lift W/ Add-A-Leaf
3" performance Accessories Body Lift
2" Torsion Keys
2" Lift Shackles
Sky Jacker RS Nitro 8000 Shock Absorbers
315/70/R17 Dick Cepek Crusher Tires
17"x9" American Racing ATX Chamber Rims Backspacing is 4.250"
172dB Dragon Roar Train Horn
COMING SOON: Light Force Striker 170 HID Fog LIghts
 Profile
PostPosted: Mon Jun 15, 2009 9:43 am
User avatar
Colorado Fan
315/75/16=35/12.50
Not sure what your asking.
_________________
Lifted Club Member #179
TOTW Winner Week #31 2008
Gun Toting American Club Member #55
CAI, Gutted Cat, Magnaflow, PCMforless Tune, New Head! (Thanks GM)
3" TB Crank, BJ flip w/1/4" Spacer, 2" Bubaloo Shackle, 2" Procomp AAL
32X11.50's on 15X8 Rockcrawlers
**SINSITY KUSTOMZ**
 Profile
PostPosted: Mon Jun 15, 2009 5:50 pm
User avatar
Colorado Z71 Owner
Colorado Z71 Owner
Yes, since you're wanting to mount a wider tire than SJ specs, you'll need to adjust the BS smaller to compensate for the added tire width. Otherwise, you'll run into troubles with the inner sidewall rubbing on the upper ball joint. The potential problem here is: as the outer edge of the tire moves farther outboard (a result of less backspacing and compounded by the wider tire itself), you run into problems with interference at the lower valance on the front bumper, and with the lower edge of the rear of the front wheel well. Obviously this is when the steering is turned and/or the suspension is flexed. The front body mount has been a point of interference with the 35s also, I believe. A few have cut off the offending portion for clearance and welded in a plate to restore structural integrity.
I'm running 3.625" BS with my 305s so 3.5" BS will most likely work for you with a 35x12.50 if you have the 4" SJ lift and a 3" BL and are willing to crank the TBs a little. Can't be absolutely sure what the extra diameter will do to you though. Just depends on how close to a true 35" dia. the tire is, how wide your wheel is, etc.
_________________
 Profile
PostPosted: Tue Jun 16, 2009 3:28 pm
User avatar
2007 GMC Canyon Z71
What size rim you looking at? Skyjacker calls for a 17" wheel.
_________________
Steve
 Profile
PostPosted: Tue Jun 16, 2009 4:46 pm
User avatar
Colorado Fan
u can run 15s on it if u want. a few people on here are and so am i ina week.
_________________
05Rado Z71
Under 35,000 miles :)
Lifted Colorado Club Member #269
 Profile
PostPosted: Wed Jun 17, 2009 12:59 am
User avatar
Colorado Fan
I was looking at 15" rims but not limiting myself to them. I'll probably go with 15" or 16" x 8" rims with a 3.5" backspacing. I know the tires will mount and not rub the ball joints. Dents and Ding's truck is an '04 and soo would sit lower (from stock) than mine, hopefully the higher stance will clear me of my fender.
Worst case scenario, I end up cutting off some body mount, I don't really want to but i want to run 35's more. Is there a 34" tire equivilent?
_________________
2" Torsion Keys
2" Lift Shackles
 Profile
PostPosted: Wed Jun 17, 2009 10:03 am
User avatar
Colorado Z71 Owner
Colorado Z71 Owner
You can save quite a bit of money on a set of tires by staying with the 15" hole.
_________________
 Profile
PostPosted: Wed Jun 17, 2009 9:14 pm
User avatar
Colorado Fan
sounds good to me i staying with 15s :D
_________________
05Rado Z71
 Profile
PostPosted: Thu Jun 18, 2009 12:47 am
User avatar
Colorado Fan
Mee too!
_________________
2" Torsion Keys
2" Lift Shackles
 Profile
PostPosted: Thu Jun 18, 2009 2:33 am
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 4 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
[ Privacy Statement ]
