It is currently Thu Sep 02, 2010 4:33 pm
Post new topic Reply to topic  [ 9 posts ]
Installing 3" Body Lift
Author Message
 Post subject: Installing 3" Body Lift
Colorado Fan
OK heres the deal... i have an 05' GMC canyon z71 4X4 reg cab... i have the CST 5" suspension lift with the 1" rear shackle... my truck sits real nice right now... However after about a year of haveing the lift on.. i want to go higher... i really want to do the 3" PA BL but dont want to pay the 500 bucks for install... I know ppl here who have installed the BL before... just wanted to really know if it would be easy/ possible to do with just my self installing... LET ME KNOW! thanks in advance...
 Profile
PostPosted: Wed Feb 04, 2009 11:42 am
 Post subject: Re: Installing 3" Body Lift
User avatar
2009 SESM COORDINATOR
2007 GMC Canyon Z71
It is possible. I did mine. Not sure I would use the term easy. Just takes time (and the correct fan clutch spanner wrench).
_________________
Steve
2007 GMC Canyon Z71-4x4 Crew Cab | 3.7 I5 - Auto | 4" Skyjacker suspension lift | 3" Performance Accessories body lift | 33x11.5x17 tires (going 35x12.5x17) | 3.73 gears | Custom blurred grille | 57 K&N | BPi VS | AMS EaAU 6081 | SSK MAF Adapter | NGK AFX w/ NTK WBO2 | HP Tuner Pro wideband tuned by ME! | AMSoil fluids FTW!
Image............2010 SESM Oct 22-24 Details Here
 Profile
PostPosted: Wed Feb 04, 2009 11:53 am
User avatar
Canyon Z71 Owner
Canyon Z71 Owner
2005 GMC Canyon Z71
I used a big set of channel locks on the fan clutch nut.
_________________
05 Canyon EC SLE - I5M Z71 GT4
V1 | FRAM Boost+RamAir | LED + HAW Strobes | BFG 33-12.5-15
Rancho | Bubaloo Skidz | MBRP Dumped System
Cat Gut| 3 x Lightforce Blitz | eFan | PCMforless <- very unhappy
1.5" TB/AAL/1" BL | Fold-A-Cover | Line-X OTR | Brake Box
 Profile
PostPosted: Wed Feb 04, 2009 11:55 am
User avatar
2007 GMC Canyon Z71
I tried that. Did not work for me. Had to drive around town (in a spare truck) to get a spanner wrench. The first did not work either......Eventually the THIRD worked!
_________________
Steve
 Profile
PostPosted: Wed Feb 04, 2009 12:46 pm
Colorado Fan
right on... so do u know the type or size of the correct spanner wrench?
 Profile
PostPosted: Wed Feb 04, 2009 2:07 pm
User avatar
Canyon Z71 Owner
Canyon Z71 Owner
2005 GMC Canyon Z71
Slightly bigger than a 10" crescent hammer.
_________________
 Profile
PostPosted: Wed Feb 04, 2009 2:49 pm
User avatar
2007 GMC Canyon Z71
This is what I had success with.
http://www.tooldesk.net/pages/KDT3471.aspx
_________________
Steve
 Profile
PostPosted: Wed Feb 04, 2009 4:47 pm
Colorado Fan
thanks guy ... really appreciate the good info... i just found out my wheel bearing/hub assembly needs to be replaced and so that puts a bit of a damper on buying the BL right now.. but i will print out this info for when i do ... thanks again!
 Profile
PostPosted: Wed Feb 04, 2009 5:12 pm
User avatar
2007 GMC Canyon Z71
Was able to use O'Reilly Auto Part's loaner program to borrow the spanner wrench.
_________________
Steve
 Profile
PostPosted: Wed Feb 04, 2009 7:02 pm
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 4 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
[ Privacy Statement ]
