It is currently Thu Sep 02, 2010 4:30 pm
Post new topic Reply to topic  [ 16 posts ]
Coil spring shocks
Author Message
 Post subject: Coil spring shocks
User avatar
Colorado Z85 Owner
Colorado Z85 Owner
Well today the weather was pretty nice for working outside. Mid 70's. I purchased the suspension max coil spacer kit about 4 months ago. I also purchased new shocks about 2 months ago on amazon.com. And I got my new wheels today.
So I start tearing into the project. Get the shock assembly out and take it apart. I take the new shock out of the box and to my surprise it's 2" shorter and it has no spring perch. :evil:
So I think it's not that big of a deal so I go to Autozone. I take the old shock with me to compare. They pull 2 from their stock and again it's the wrong one, 2" short and no spring perch!
That was the only option they had.
So off to Oreilly autoparts. The have none in stock, not even at their regional warehouse. They have some in a warehouse here in Houston but there is no store front so I can't go get'em. They ordered them and they'll be here Monday.
But that's not all... They cost $82 each!
WTF, why are parts hit or miss with the 355's? This isn't the first part I have had trouble getting.
Oh well, I did as much as I can today so Monday hopefully all I have to do is assemble the shock assembly and bolt it back on. Then I can go get my new tires and get an alignment.
I am going to assume that the shocks I have are for the Z71. If so I have a pair for sell :?
_________________
Conservative Club Member #35
My Gallery
 Profile
PostPosted: Sat Jan 23, 2010 7:17 pm
 Post subject: Re: Coil spring shocks
User avatar
Canyon Z85 Owner / Moderator
2007 GMC Canyon Z85
the perch comes off the old shock brother. as far as the lentght not sure,
_________________
The Wolf! QA1 Rydahs!
http://www.355nation.net/forum/sinsity- ... 010-a.html
 Profile
PostPosted: Sat Jan 23, 2010 11:04 pm
User avatar
Colorado Z85 Owner
Colorado Z85 Owner
Are you sure. I really don't think it comes off the old ones. It appears to be clamped to the old one and if I did get it off there is nothing on the other shocks that would have held it in place.
Here is a pic from rock auto.
_________________
My Gallery
 Profile
PostPosted: Sun Jan 24, 2010 4:10 am
User avatar
2007 TOTY / Moderator
2005 Chevrolet Colorado Xtreme
Yup, the stock perch comes off. Ron has had his off and put on his QA1 coilovers.
_________________
Image <~~~ click it! :mrgreen:
 Profile
PostPosted: Sun Jan 24, 2010 4:32 am
User avatar
2007 GMC Canyon Z85
it is just pressed on. you can tap it off with a dead blow hammer, or block of wood. true story
_________________
 Profile
PostPosted: Sun Jan 24, 2010 12:32 pm
User avatar
Colorado Z85 Owner
Colorado Z85 Owner
You guys are a big help! I just need to figure out how to line the perch on the new one. Back to the autoparts store. Hopefully they have shocks with the seat for the perch.
So the shocks I have don't have the seat for the perch and they are 2" too short. I guess I'll sell them on ebay or somewhere.
It still sucks I couldn't find new ones with the perch already installed in stock anywhere.
Thanks again.
_________________
My Gallery
 Profile
PostPosted: Sun Jan 24, 2010 1:33 pm
User avatar
2007 GMC Canyon Z85
you wont find them, the perch seat is just 2 raised areas on the shock body. alignment is non-issue, cus you can line it all up when assembling.
_________________
 Profile
PostPosted: Sun Jan 24, 2010 3:36 pm
User avatar
Colorado Z85 Owner
Colorado Z85 Owner
Here's the deal. I still couldn't find shocks that would accept the spring perch. Thinking about it it would be hard to find a similar sized diameter shock with the same mounting point, unless it was the same brand.
I went to Oreilly, and Autozone again to find one and couldn't. I didn't bother with Advanced. I called Pep Boys and they could order them, but didn't stock them and there would be a 4 day ship time.
So I try Napa, there a bit far from my house but at this point I will try anything if they have them in stock. They do, and most Napa locations in Houston have them. They are Monroe sensa trac 71353 I paid $146.03 total.
_________________
My Gallery
 Profile
PostPosted: Sun Jan 24, 2010 3:40 pm
User avatar
2007 GMC Canyon Z85
did they have the perches on them?
_________________
 Profile
PostPosted: Sun Jan 24, 2010 11:34 pm
User avatar
Colorado Z85 Owner
Colorado Z85 Owner
Yes, the one's I bought did. The old spring perch wouldn't slide over the new one because the new shocks are a larger diameter.
Here's a pic of the new shocks.
_________________
My Gallery
 Profile
PostPosted: Mon Jan 25, 2010 12:10 pm
User avatar
2007 GMC Canyon Z85
that looks hella short in the pic. when you have them dis assembelde take side by side pic please.
_________________
 Profile
PostPosted: Mon Jan 25, 2010 3:16 pm
User avatar
Colorado Z85 Owner
Colorado Z85 Owner
The shaft is actually longer by about a half inch or so. I have already installed the drivers side. It took me a long time to get it in because I had to do a lot of grinding on the bump stop mount to install the 2.5" suspension max spring mount spacer.
I'll get some pics when I get home.
_________________
My Gallery
 Profile
PostPosted: Mon Jan 25, 2010 4:05 pm
User avatar
Colorado Z85 Owner
Colorado Z85 Owner
Here's a pic of the shocks. From left to right, old shock with spring still assembled, old shock without perch, new correct shock with plastic spring guide on top of flat spring perch, new shock I purchased a few months ago from amazon.com that for whatever reason a few auto parts stores and online vendors have listed for the Z85 2wd coil suspension and bottom, spring perch from old shock.
_________________
My Gallery
 Profile
PostPosted: Mon Jan 25, 2010 10:44 pm
User avatar
2007 GMC Canyon Z85
cool man, thanks for the pics. im sure this will help some others out.
_________________
 Profile
PostPosted: Tue Jan 26, 2010 1:48 am
User avatar
Colorado Z85 Owner
Colorado Z85 Owner
No problem. Got the other one on today. I test drove it around the neighborhood and they are quite a bit stiffer, not sure how much the 2.5" lift has to do with that. They also need to get broken in. I need new tires BAD so I haven't driven it except for in the neighborhood. I'm getting new tires tomorrow morning and an alignment right after that.
_________________
My Gallery
 Profile
PostPosted: Tue Jan 26, 2010 6:12 pm
User avatar
2007 GMC Canyon Z85
post up some pics when its all done.
_________________
 Profile
PostPosted: Tue Jan 26, 2010 11:30 pm
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 6 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
[ Privacy Statement ]
