It is currently Thu Sep 02, 2010 4:30 pm
Post new topic Reply to topic  [ 9 posts ]
lowering help
Author Message
 Post subject: lowering help
Colorado Fan
i can work on engines all day long and not have many questions, but i know very little about suspensions. i know most of the main components but after reading many topics and posts im still left with questions.
i have an 04 z85 and want to do a 2/3 drop. im lookin to put 18's or 20's on it and want to stay around a 45-50 series tire. ive seen all sorts of kits for this but each is different. obviously i need springs and from what i understand i dont need shocks but it is advisable. now is this front or front and rear? also do i need drop spindles? i keep hearing about these blocks for the rear, but i havent seen any pics of them nor do i understand how they work or where they go. any info would be greatly appreciated. i read the write up on lowering but im still not gettin it.
_________________
04 Chevy Colorado extended cab
2.8L, Z85 2WD,
2" suspension max lift springs
2" shackles
flowmaster super 44
K&N air filter
93 Cadillac Sedan Deville
black w/ black leather interior, 4.9L
 Profile
PostPosted: Wed Feb 03, 2010 3:59 am
 Post subject: Re: lowering help
User avatar
Colorado Curious
You can do a quick search for lowering, but here is a quick rundown.
For the front you can either get lower springs to replace yours, drop spindles (usually dont need these unless you want to REALLY drop your truck), or you can do what I do and get some Beltech Drop Lower Ball joints. These use the stock springs, and just relocate the lower ball joint to lower the front end.
For the back, the easiest is blocks (what Most people use), shackles, or if you really want to, replace the leaf springs.
I have a 2-2 Ball-joint/Block Drop and I run 20" wheels with a 45 sidewall and I dont have any rubbing problems at all.
Hope this helps some!
 Profile
PostPosted: Wed Feb 03, 2010 7:15 pm
Colorado Fan
They go between your axle and leaf springs. On these trucks the rear suspension setup is spring under axle, so blocks lower instead of lifting like on bigger trucks.
_________________
Mud Club Member #22
Beige '01 Silverado ECSB z71 5.3
2" Rough Country leveling keys
18" glasspack 45'd
 Profile
PostPosted: Wed Feb 03, 2010 11:16 pm
User avatar
Canyon Z85 Owner / Moderator
2007 GMC Canyon Z85
correct. bigger the block, the more drop. you also DO NOT have to replace rear shock. the shock hanger stays in the same place, only the axle moves up.
springs, or bjs up front and your golden.
_________________
The Wolf! QA1 Rydahs!
http://www.355nation.net/forum/sinsity- ... 010-a.html
 Profile
PostPosted: Wed Feb 03, 2010 11:43 pm
Colorado Fan
good to know. so for a 2/3 drop theres not as much involved as i thought. hows the ride with the ball joint drop?
_________________
2.8L, Z85 2WD,
2" shackles
flowmaster super 44
K&N air filter
 Profile
PostPosted: Thu Feb 04, 2010 12:52 pm
Colorado Fan
i get that belltec is a big name around here & im sure its due to quality, but has anyone used this? if so whats your opinion of it.
http://cgi.ebay.com/ebaymotors/Lowering-Kit-04-08-07-06-05-CHEVY-GMC-CANYON-COLORADO_W0QQcmdZViewItemQQhashZitem27a1584aeeQQitemZ170210642670QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
i have a question into the seller cause the way im reading this is that the shocks are for the rear. everything ive gathered from here says the shocks are needed for the front. also is there anywhere cheaper to get the belltec balljoint? $375+shipping seems a bit much to me.
_________________
2.8L, Z85 2WD,
2" shackles
flowmaster super 44
K&N air filter
 Profile
PostPosted: Thu Feb 04, 2010 1:19 pm
Colorado ZQ8 Owner
Colorado ZQ8 Owner
2005 Chevrolet Colorado ZQ8
I think NLC has some belltech drop joints for 270 check his for sale thread.
_________________
2005 Crew Cab Zq8
10,000k hids in highs
10,000k hids in lows
10,000k hids in fogs
high low and fog kit
blacked out fog light housing
totally debadged
smoked led 3rd tail light
smoked led brake lights
Xtreme wheels
2" drop
low pro transmission crossmember
 Profile
PostPosted: Thu Feb 04, 2010 1:51 pm
User avatar
Colorado Curious
I have the ball-joint drop and i think that the ride is good... maybe better than drop springs... but I would have to drive a colly with drop springs to really see the difference...
 Profile
PostPosted: Thu Feb 04, 2010 11:47 pm
User avatar
2007 GMC Canyon Z85
any bell tech, or djm, pm norcalss for all your needs. very cool ass cat to work with. and he knows our trucks very well.
_________________
 Profile
PostPosted: Thu Feb 04, 2010 11:56 pm
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 6 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
[ Privacy Statement ]
