It is currently Thu Sep 02, 2010 4:31 pm
Post new topic Reply to topic  [ 4 posts ]
tuned for no cats...
Author Message
 Post subject: tuned for no cats...
Colorado Fan
Hey, got my PCM4less done, and installed, and I remember that I had it tuned with no cats. I thought I would need to do this because of the manifold cat gut, now I am starting to think I may have made a mistake by doing this?? What/if anything did I do?
_________________
2006 Canyon Z71 4x4. Homemade CAI, gutted manifold cat, Magnaflow muffler, Vette servo, Delco iridiums, Mobil 1, H3 springs and TB keys lift, Geolander A/T 32"X11.5's on stock wheels. PCMFORLESS
 Profile
PostPosted: Sun Mar 15, 2009 6:11 pm
 Post subject: Re: tuned for no cats...
User avatar
2009 SESM COORDINATOR
2007 GMC Canyon Z71
Maybe? It depends on if PCM4less actually acted on that information. Our PCMs have CAT Over Temp protection built in where it will add fuel when the CAT is seeing extremely high exhaust temps to help cool the exhaust to prevent from melting the CATs. There are enable/disable, temp and fueling thresholds that could be adjusted. I typically disable this for tuning but re-enable in when I am done. If I was told no cats and did not physically look under the vehicle then I would disable COT. Running to hot thru the will decrease the CAT's effectiveness and may cause you not to pass emissions. If the temps are high enough for long enough if could also damage the cat. I would suggest calling PCM4less to see if they can look it up and see what they advise.
_________________
Steve
2007 GMC Canyon Z71-4x4 Crew Cab | 3.7 I5 - Auto | 4" Skyjacker suspension lift | 3" Performance Accessories body lift | 33x11.5x17 tires (going 35x12.5x17) | 3.73 gears | Custom blurred grille | 57 K&N | BPi VS | AMS EaAU 6081 | SSK MAF Adapter | NGK AFX w/ NTK WBO2 | HP Tuner Pro wideband tuned by ME! | AMSoil fluids FTW!
Image............2010 SESM Oct 22-24 Details Here
 Profile
PostPosted: Mon Mar 16, 2009 5:02 am
Colorado Fan
Location: Granite City, IL (Actually just east of STL but close enough. And no not East STL either)
Wouldn't running the engine richer lead to more fuel getting into the exhaust causing the cat to heat up more?
 Profile
PostPosted: Mon Mar 16, 2009 8:49 pm
User avatar
2007 GMC Canyon Z71
Yes, extremely rich will melt the cats but when the cats are seeing elevated temps (1700+) then fuel is added to cool the exhaust and increase the efficiency of the cat (not necessarily increasing MPG).
_________________
Steve
 Profile
PostPosted: Mon Mar 16, 2009 8:55 pm
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 2 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
[ Privacy Statement ]
