It is currently Thu Sep 02, 2010 4:29 pm
Post new topic Reply to topic  [ 14 posts ]
How To: Window Crank Removal with a shop rag
Author Message
 Post subject: How To: Window Crank Removal with a shop rag
Colorado Z85 Owner
Colorado Z85 Owner
I looked around here and didn't see a How To posted on window crank removal without the specialty tool, so I thought that I'd make one.
If you go to other place's how to sites, all they do to tell you how to remove your window crank with a rag is;
"Use a shop rag with a "shoeshine" motion to release C clip on rear of crank and remove".
Well, I don't know about you guys, but this is not exactly descriptive for the ones who have never done this before. So, I give you pictures........
First off, I put a flat head screw driver in behind the window crank to make space between the window crank and the plastic ring so the rag will squeeze in there.
Here is a close up pic of where the screw driver needs to go and you can see the clear plastic ring that needs to be pushed back.
Now take your shop rag. Hold one corner in each hand and slowly work it between the crank and the plastic ring as you can see in this pic.
Now after you make sure that the rag is in place, remove the screw driver. If you look closely you can see the rag in between the plastic ring and the crank.
Now that the rag is in place, you can start doing the shoe shine thing with it. Make sure that you are holding on to the corners of the rag as you go back and forth. You might have to move the rag around in order to grab the clip. Once you get the clip off, you will notice that the crank pops out slightly. Once you pull it off, you will see this.........
This little clip is what is keeping your window crank in place. Once the rag grabs ahold of it and you do your shoe shine technique, it will come off.
Upon reinstalling the window crank, you must remove the clear plastic ring, reinstall the clip into it's slots(you can see them if you look closely on the crank), then reinstall the clear ring. At this point, all you have to do is to push the crank back on.
It's really an easy process that should take no more than 5 minutes tops after you've got the hang of how to do it.
Enjoy!
_________________
2006 Chevy Colorado regular cab
2.8L 5 speed manual
Dynomax Super Turbo muffler
K&N drop in air filter
factory snorkel replaced by 3" pipe
Mr. Tailight High/Low/Fog Light Kit
 Profile
PostPosted: Fri Nov 18, 2005 4:05 am
 Post subject:
User avatar
Silverado Owner
2004 Chevrolet Colorado Z71
I added it to the sticky at the top.
_________________
Marty
Former 04 DGM Z71 Colorado LS / Current Victory Red Silverado LT2
 Profile
PostPosted: Fri Nov 18, 2005 1:46 pm
 Post subject:
User avatar
Colorado Fan
thanks for the good info.
_________________
ryan
 Profile
PostPosted: Sat Nov 19, 2005 12:34 am
 Post subject:
User avatar
Colorado Z85 Owner
Colorado Z85 Owner
Thanks for the tip...I'm putting some new speakers in my truck this weekend and will be needing it. I have always used just a screwdriver in the past and it was always a pain in the ass!
_________________
Matt
'05 Colorado (ZQ8 wannabe) My Gallery
'96 Camaro Z28 - 11.9 @ 118mph
 Profile
PostPosted: Sat Nov 19, 2005 2:58 am
 Post subject:
User avatar
Canyorado ZQ8 Owner
2004 Chevrolet Colorado Z85
wow, i wish this was posted about a year ago...i used a awl and a flat head...not the best choice but worked...this looks alot nicer, ill try it tomarrow
_________________
04 z85 5cyl 5 speed RC - only a handful of mods
15.1 in the 1/4
http://www.HOU355.com
Remember kids, its not what you know - but who you know; and how much brown-nosing you do.
rangerbob
“What a pompous ass you are. I think you beat out me and Dillusion.”
 Profile
PostPosted: Mon Nov 21, 2005 1:46 am
 Post subject:
User avatar
Colorado Curious
I saw this in the sticky, cool trick. You can also just spend a few dollars and buy the tool.
_________________
2007 Chevy Colorado 2WD Z85 1LT- Victory Red
 Profile
PostPosted: Thu Apr 05, 2007 6:23 pm
 Post subject: Re: How To: Window Crank Removal with a shop rag
User avatar
Colorado Z71 Owner
Colorado Z71 Owner
i just use a flat head...no rag. i just grab the horseshoe shaped part and pop it out.
_________________
Cullinan
Georgia Chapter Member
Lifted Member 164
2004 Colly Z71 Reg Cab (2WD)
Hunter Grille/Brush Guard
Rhino Lining Double Thickness "Tuff Stuff"
Sirius Sportster 4 Sat. Radio
http://www.coloradofans.com/forums/gallery/album_personal.php?user_id=16405
didn't realize that facebook albums are only visible to facebook members. links = trash. i'll see what i can do to get them up in another album.
 Profile
PostPosted: Tue Apr 29, 2008 9:56 pm
User avatar
Colorado Z71 Owner
Colorado Z71 Owner
it was a good idea, i did it last weekend when i put in my new 250 watt sony xplods in the doors, which i got to say sound a hell of alot better then those shitty stock 15 watt speakers!
_________________
Atxcoloradofans Truck Click Here!
Mud Club Member #19
Lifted Club Member #195
 Profile
PostPosted: Thu May 01, 2008 3:50 pm
ColoradoFans Newbie
I wanted to let everyone know that this FAQ was a HUGE help to me. I started to take my door panel off because the geniuses at Chevrolet decided the best place for a cupholder was directly next to the speaker. As expected, at some point a Cheerwine cup popped it's lid in the toddler-sized cupholder, leading my entire speaker to become doused in soda.
After getting stuck on the window crank, I said "Oh no, I REALLY do not want to give my money to those morons at the dealership". Thankfully, with some searching and anxiety, I found this thread. I was able to get the crank off and install a replacement speaker in less than 1 Hour of work (I did it slowly to make sure I wasn't breaking anything else).
The window crank ended up being the easiest part of the process.
_________________
Swag Bucks - Free Gifts/Collectibles just for searching Google
Uncovered Films - Indie/Cult/Underground Movie coverage
 Profile
PostPosted: Wed Feb 25, 2009 4:18 pm
Colorado Fan
Or you could spend 10 bucks and buy the correct tool and have it forever. But a nice trick if your in a pinch
 Profile
PostPosted: Wed Feb 25, 2009 8:04 pm
User avatar
ColoradoFans Newbie
Sorry for the bump, but this trick works great, got my crank off in a second with it and didn't damage the clip.
 Profile
PostPosted: Thu Oct 22, 2009 3:44 pm
User avatar
Colorado Fan
2005 GMC Canyon Z71
sweet thanks i got Alpine sps600's Im putting in my doors sometime this week . thanks
_________________
DKTAGMC
-Wolo Air Horn
-Window Visors
-3" Tb crank/2" shackles/ Lifted Club member #301
-Pro Sound Exhaust
-Vinyl Hood Stripes/Strobe Stripes
-Hunter Brush Guard
-Pioneer HU/Alpine Type S speakers/12" Sony xplode
 Profile
PostPosted: Sun Jan 03, 2010 6:26 pm
User avatar
Colorado Fan
2005 GMC Canyon Z71
that tip saved me idk how much time...THANKS
_________________
DKTAGMC
-Wolo Air Horn
-Window Visors
-Pro Sound Exhaust
-Hunter Brush Guard
 Profile
PostPosted: Sat Feb 27, 2010 11:10 pm
User avatar
Colorado Curious
2006 Chevrolet Colorado Z85
or you can buy a door handle remover for $6.
_________________
Barack Obama, thats what happens when stupid people vote.
 Profile
PostPosted: Mon Mar 01, 2010 1:27 am
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 2 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
[ Privacy Statement ]
